electronics_diy_common_tools
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
electronics_diy_common_tools [2016/07/18 15:39] – [General] psykhaze | electronics_diy_common_tools [2016/07/19 15:07] (current) – [General] psykhaze | ||
Line 9: | Line 9: | ||
==== General ==== | ==== General ==== | ||
+ | - **Workbench** - Protect your house, have a proper work area | ||
+ | - **Storage Unit** - Put your tools and components somewhere safe | ||
+ | - **Small Plastic Cups** - Somewhere to put things temporarily. Don't leave your kit lying around. | ||
+ | ==== Safety ==== | ||
+ | - **Safety Glasses** - Protect your sense of sight | ||
+ | - **Face mask** - Protect your lungs | ||
+ | - **Fire Extinguisher** - Don't let your soldering iron start a fire you can't put out | ||
+ | - Fire Blanket - As above | ||
+ | - Soldering Smoke Absorber/ | ||
{{youtube> | {{youtube> | ||
- | * **Workbench** - Protect your house, have a proper work area | + | \\ |
- | * **Storage Unit** - Put your tools and components somewhere safe | + | |
- | * **Small Plastic Cups** - Somewhere to put things temporarily. Don't leave your kit lying around. | + | |
- | ==== Safety ==== | + | |
- | * **Safety Glasses** - Protect your sense of sight | + | |
- | * **Face mask** - Protect your lungs | + | |
- | * **Fire Extinguisher** - Don't let your soldering iron start a fire you can't put out | + | |
- | * Fire Blanket - As above | + | |
- | * Soldering Smoke Absorber/ | + | |
=====Electrical Instruments===== | =====Electrical Instruments===== | ||
Line 34: | Line 34: | ||
=====Soldering ===== | =====Soldering ===== | ||
* Soldering Iron Tip Cleaner - Take care of your tools | * Soldering Iron Tip Cleaner - Take care of your tools | ||
Line 48: | Line 48: | ||
=====Trimming and Fastening===== | =====Trimming and Fastening===== | ||
+ | * **Cutters** - For trimming componenet leads | ||
+ | * **Screwdriver Set** - Various sizes | ||
+ | * IC Puller / Placer | ||
* Wire Strippers - For stripping insulation from cabling | * Wire Strippers - For stripping insulation from cabling | ||
* Pliers Set - Various Sizes and types | * Pliers Set - Various Sizes and types | ||
- | * Side Cutters - For trimming componenet leads | ||
- | * Screwdriver Set - Various sizes | ||
- | * Spanner Set - Various sizes, including shifter spanners | ||
- | * Socket Set - Various sizes | ||
- | * IC Puller - Little tool for pulling IC's from sockets | ||
- | * IC Placer - Little tool for putting IC's in sockets, spreads even pressure over all the pins | ||
* Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach | * Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach | ||
* IDC Crimping Tool - Because doing it with pliers sucks | * IDC Crimping Tool - Because doing it with pliers sucks | ||
- | * Electrical Tape - Too many uses to list | + | * Electrical Tape |
=====Misc===== | =====Misc===== | ||
* Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach | * Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach | ||
* Compressed Air Can - For cleaning stuff by blasting off dust | * Compressed Air Can - For cleaning stuff by blasting off dust |
electronics_diy_common_tools.txt · Last modified: 2016/07/19 15:07 by psykhaze
