electronics_diy_common_tools
DIY Common Tools for Electronics
You will find Here a List of Common Tools Used For Electronics DIY.
You don't absolutely need to have all of these things, but it sure helps!
Using a tool for purposes other than those for which it was designed can be just a little more difficult, or downright dangerous. Please be safe :)
General / Safety
General
  1. Workbench - Protect your house, have a proper work area
  2. Storage Unit - Put your tools and components somewhere safe
  3. Small Plastic Cups - Somewhere to put things temporarily. Don't leave your kit lying around.
Safety
  1. Safety Glasses - Protect your sense of sight
  2. Face mask - Protect your lungs
  3. Fire Extinguisher - Don't let your soldering iron start a fire you can't put out
  4. Fire Blanket - As above
  5. Soldering Smoke Absorber/Ventilator - MMmmm, Lead smoke. Mmmmm, Cancer. Mmmm, Insanity. Mmm…. I think not.
Electrical Instruments
  1. Multimeter - For testing circuitry Voltages, Resistors and Transistors
  2. Oscilloscope - For testing signals. Dual trace is better , allow signals comparison
  3. Power Supply - Regulated lab power supply . Help in getting the right Voltages inputs
Video Tutorials
Soldering
  1. Soldering Iron or Station with Stand- Temperature controlled
  2. Solder - Good quality solder for good quality joints, 63/37 Eutectic
  3. Desoldering Pump - - For removing soldered chips
  • Soldering Iron Tip Cleaner - Take care of your tools
  • Tinning Block - for taking care of soldering iron tips
  • PCB Holders - Make soldering easier and cleaner
Trimming and Fastening
  • Cutters - For trimming componenet leads
  • Screwdriver Set - Various sizes
  • IC Puller / Placer
  • Wire Strippers - For stripping insulation from cabling
  • Pliers Set - Various Sizes and types
  • Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach
  • IDC Crimping Tool - Because doing it with pliers sucks
  • Electrical Tape
Misc
  • Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach
  • Compressed Air Can - For cleaning stuff by blasting off dust
electronics_diy_common_tools.txt · Last modified: 2016/07/19 15:07 by psykhaze
