findbuddha
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
findbuddha [2011/08/07 06:18] – findbuddha | findbuddha [2012/02/03 07:58] (current) – Added some issues findbuddha | ||
Line 1: | Line 1: | ||
- | {{: | + | All files on this page are for DIY/ |
+ | Big thanks to TK, nILS, Wilba and anyone else who helped! | ||
- | All files on this page are for DIY/ | ||
DESIGN SOFTWARE USED: | DESIGN SOFTWARE USED: | ||
Line 10: | Line 11: | ||
A Sketchup plugin to export to .svg: http:// | A Sketchup plugin to export to .svg: http:// | ||
Inkscape for .svg editing: www.inkscape.org/ | Inkscape for .svg editing: www.inkscape.org/ | ||
MANUFACTURING: | MANUFACTURING: | ||
Line 15: | Line 17: | ||
Chassis and front panel are from www.ponoko.com (New Zealand hub). Materials include acrylic: 3mm Black (frosted 1 side), 3mm Clear, 4.5mm Arctic Ice; and 7mm veneered MDF.\\ | Chassis and front panel are from www.ponoko.com (New Zealand hub). Materials include acrylic: 3mm Black (frosted 1 side), 3mm Clear, 4.5mm Arctic Ice; and 7mm veneered MDF.\\ | ||
PCBs were manufactured at Gold Phoenix. Dimensions and layout were chosen/ | PCBs were manufactured at Gold Phoenix. Dimensions and layout were chosen/ | ||
WARNING!!!! | WARNING!!!! | ||
Line 21: | Line 24: | ||
I have endeavoured to only share files that I have used to get PCBs, panels etc. produced. If this is not the case it will be noted. I do not plan to produce corrected design files unless I need them for myself.\\ | I have endeavoured to only share files that I have used to get PCBs, panels etc. produced. If this is not the case it will be noted. I do not plan to produce corrected design files unless I need them for myself.\\ | ||
Use of these designs is at your own risk. A list of currently known issues follows:\\ | Use of these designs is at your own risk. A list of currently known issues follows:\\ | ||
KNOWN ISSUES / BUILD SUGGESTIONS: | KNOWN ISSUES / BUILD SUGGESTIONS: | ||
+ | - 2x5 connectors in seq PCB were not flipped to take into account being on the bottom of the board. This is correctable by swapping the wires as needed in the ribbon cable from the DIN/DOUT PCBs.\\ | ||
- 5x17.brd contains an error due to a problem in TK's original BLM schematic. I'll be working on a software fix for this, it should be simple.\\ | - 5x17.brd contains an error due to a problem in TK's original BLM schematic. I'll be working on a software fix for this, it should be simple.\\ | ||
- blm-full.* are currently untested, except as used in the 5x17.brd. The above schematic error is corrected.\\ | - blm-full.* are currently untested, except as used in the 5x17.brd. The above schematic error is corrected.\\ | ||
- | - blm-scalar.* contain an error. Pins I4-I7 are mirrored. This is easily fixed with a connector modification, | + | - blm-scalar.* contain an error. Pins I4-I7 are mirrored. This is easily fixed with a connector modification, |
- | - seq-cs.* if more than 1 LED is lit per cathode the switches on that cathode don't work. Any assistance on this matter would be much appreciated! :)\\ | + | |
- P3-frontpanel.svg has blue (cut) lines around engraving marks for some of the fader scale lines. I have worked around this by filling the holes with paint.\\ | - P3-frontpanel.svg has blue (cut) lines around engraving marks for some of the fader scale lines. I have worked around this by filling the holes with paint.\\ | ||
- | - Good idea to request ponoko to do the engraving on the matte side. My prototyping runs came with the engraving on the glossy side. | + | - Good idea to request ponoko to do the engraving on the matte side. My prototyping runs came with the engraving on the glossy side.\\ |
- | - Some sanding is required to get LCD windows and button caps to fit correctly. | + | - Some sanding is required to get LCD windows and button caps to fit correctly.\\ |
- | - Check LED orientation prior to soldering - it may not match the outline printed on the board. | + | - Check LED orientation prior to soldering - it may not match the outline printed on the board.\\ |
- | Design files are currently in here: | + | |
- | {{: | + | DESIGN FILES: |
findbuddha.txt · Last modified: 2012/02/03 07:58 by findbuddha
