mb-modulbox-ng
Differences
mb-modulbox-ng [2016/08/10 04:15] – [Frontpanels Layouts] psykhaze | mb-modulbox-ng [2016/08/15 00:46] – old revision restored (2016/08/10 04:04) psykhaze | ||
Line 88: | Line 88: | ||
^ Module | ^ Module | ||
- | |Main UI+Main PCB|1 |Jacksx16 | + | |Main UI+Main PCB|1 |Jacksx16 |
- | |Horizontal 4xOLEDS SCSE|2 | | |x1 PushRotary|Tactilex7 | + | |OLED-SCS |
- | |Vertical 4xOLEDS|3 | + | |Vertical 4xOLEDS|3 |
|LCD Vertical SCS|4 | | |LCD Vertical SCS|4 | | ||
|LCD Horizontal Extended SCS|5 | | |LCD Horizontal Extended SCS|5 | | ||
Line 112: | Line 112: | ||
|Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | |Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | ||
|Adafruit Silicon 3mm 8x8 Matrix|24| | |Adafruit Silicon 3mm 8x8 Matrix|24| | ||
- | |Joystick | + | |Sparkfun Silicon 5mm 4x4 RGB Matrix|25| |
- | |Linear Touch |26 | + | |RGB Encoder 4x4 Matrix|26| |
- | |Circular touch|27 |1x(2x)Circular Sensor|16(x2)xWS2812| | + | |Joystick |
- | |Force touch |28 | + | |Linear Touch |28 |
- | |MiniDeck DJ Control|29|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | + | |Circular touch|29 |1x(2x)Circular Sensor|16(x2)xWS2812| |
+ | |Force touch |30 | ||
+ | |MiniDeck DJ Control|31|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | ||
===== Frontpanels Layouts ===== | ===== Frontpanels Layouts ===== | ||
mb-modulbox-ng.txt · Last modified: 2016/10/08 12:53 by psykhaze
