mb-modulbox-ng
Differences
mb-modulbox-ng [2016/08/15 00:44] – [Community users working on it] psykhaze | mb-modulbox-ng [2016/08/15 00:46] – old revision restored (2016/08/10 04:04) psykhaze | ||
Line 21: | Line 21: | ||
====Main Part Features ==== | ====Main Part Features ==== | ||
- | - Core32 | + | - **[[stm32f4_core_board_parts_list|STM32F4 |
- | - **Standard Control Surface** with 6 Tactile switches, Push - Encoder , | + | - **[[scs_module|Standard Control Surface]]** with 6 Tactile switches, Push - Encoder , |
- | - **SD Card Slot+USB in** | + | - **[[sd_card_module|SD Card Slot]]** (+USB in?) |
- | - **2xMIDI IN + 2xMIDI OUT 2.5mm jack Plugs** | + | - **[[midi_io_matrix_board_parts_list|2xMIDI IN + 2xMIDI OUT 2.5mm jack Plugs]]** |
- | - **Optionnal 16x3.5mm jacks** for external **Analog Ins/Analog Outs** with External interfaces for expanding. | + | - **Optionnal 16x3.5mm jacks** for external **[[ainser64_board_parts_list|Analog Ins]]**/**[[aout_board_parts_list|Analog Outs]]** with External interfaces for expanding. |
===== Community users working on it ===== | ===== Community users working on it ===== | ||
Line 31: | Line 31: | ||
* **[[Ksir]] ** - Modulbox Original Designer - PCB Design - Programming | * **[[Ksir]] ** - Modulbox Original Designer - PCB Design - Programming | ||
* **[[Psykhaze]]** - Documentation - Frontpanel design - PCB Design - Programming | * **[[Psykhaze]]** - Documentation - Frontpanel design - PCB Design - Programming | ||
- | * **[[Latigid|Latigid On]]** | + | * **[[Latigid On]]** - PCB Design |
==== Getting Involved ? ==== | ==== Getting Involved ? ==== | ||
Line 46: | Line 46: | ||
* **[[tools# | * **[[tools# | ||
+ | =====PCB process===== | ||
+ | - KiCAD Library | ||
+ | - Schematics | ||
+ | - FootPrint Creation / Association to schematics | ||
+ | - Netlist Export | ||
+ | - Make Pcb routing - Put pinheader/ | ||
Line 67: | Line 75: | ||
===== Tech Demos Videos ===== | ===== Tech Demos Videos ===== | ||
+ | {{youtube> | ||
{{youtube> | {{youtube> | ||
Line 79: | Line 88: | ||
^ Module | ^ Module | ||
- | |Main UI+Main PCB|1 |Jacksx16 | + | |Main UI+Main PCB|1 |Jacksx16 |
- | |Horizontal 4xOLEDS SCSE|2 | | |x1 PushRotary|Tactilex7 | + | |OLED-SCS |
- | |Vertical 4xOLEDS|3 | + | |Vertical 4xOLEDS|3 |
|LCD Vertical SCS|4 | | |LCD Vertical SCS|4 | | ||
- | |LCD Horizontal | + | |LCD Horizontal |
|Encoders x8 |6 | |Encoders x8 |6 | ||
|Pots x8 |7 |Pots x8 | | | |Pots x8 |7 |Pots x8 | | | ||
Line 103: | Line 112: | ||
|Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | |Crosspoint Matrix 8x4(x4)|23|Jacksx(8+4)|x(8x4) 3mm | |Toggle 4poles, Tactilex(8+4)|16|Psykhaze| | ||
|Adafruit Silicon 3mm 8x8 Matrix|24| | |Adafruit Silicon 3mm 8x8 Matrix|24| | ||
- | |Joystick | + | |Sparkfun Silicon 5mm 4x4 RGB Matrix|25| |
- | |Linear Touch |26 | + | |RGB Encoder 4x4 Matrix|26| |
- | |Circular touch|27 |1x(2x)Circular Sensor|16(x2)xWS2812| | + | |Joystick |
- | |Force touch |28 | + | |Linear Touch |28 |
- | |MiniDeck DJ Control|29|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | + | |Circular touch|29 |1x(2x)Circular Sensor|16(x2)xWS2812| |
+ | |Force touch |30 | ||
+ | |MiniDeck DJ Control|31|1xScratchFader+ 1xVertical Fader|x8 3mm|x1 Code Wheel +x3 PushRotary| |32| | | | ||
===== Frontpanels Layouts ===== | ===== Frontpanels Layouts ===== | ||
===== Modules Ins/Outs + Related Parts ===== | ===== Modules Ins/Outs + Related Parts ===== | ||
^ . ^ 1 ^ 2 ^ 3 ^ 4 ^ 5 ^ 6 ^ 7 ^ 8 ^ 9 ^ 10 ^ 11 ^ 12 ^ 13 ^ 14 ^ 15 ^ | ^ . ^ 1 ^ 2 ^ 3 ^ 4 ^ 5 ^ 6 ^ 7 ^ 8 ^ 9 ^ 10 ^ 11 ^ 12 ^ 13 ^ 14 ^ 15 ^ | ||
| Digital Ins |8 |0> | | Digital Ins |8 |0> | ||
+ | | 74HC165 # |1 |0> | ||
| Digital Outs |/ |/ |/ |/ |/ |/ |/ |16 |/ |/ | | Digital Outs |/ |/ |/ |/ |/ |/ |/ |16 |/ |/ | ||
+ | | 74HC595 # |/ |/ |/ |/ |/ |/ |/ |2 |/ |/ | ||
| Analog Ins | | Analog Ins | ||
| CLCD # | | CLCD # | ||
| OLED # | | OLED # | ||
- | ^ . ^ 16 ^ 17 ^ 18 ^ 19 ^ 20 ^ 21 ^ 22 ^ 23 ^ 24 ^ 25 ^ 26 ^ 27 ^ 28 ^ 29 ^ | + | ^ . ^ 16 ^ 17 ^ 18 ^ 19 ^ 20 ^ 21 ^ 22 ^ 23 ^ 24 ^ 25 ^ 26 ^ 27 ^ 28 ^ 29 ^ 30 ^ 31 ^ |
- | | Digital Ins |16 |4 | + | | Digital Ins |16 |4 |
- | | Digital Outs |8 | + | | 74HC165 # |2 |
- | | Analog Ins | + | | Digital Outs |8 |
- | | CLCD # | + | | 74HC595 # |1 |
- | | OLED # | + | | Analog Ins |
+ | | CLCD # |/ | ||
+ | | OLED # | ||
===== Parts References ===== | ===== Parts References ===== | ||
Line 138: | Line 152: | ||
^ Designation | ^ Designation | ||
+ | | Serial Register IN |{{http:// | ||
+ | | Serial Register OUT |{{http:// | ||
+ | | Line Driver | ||
+ | | OptoCoupler | ||
+ | |Analog> | ||
+ | | Multiplexer switch | ||
+ | |Digital> | ||
+ | |Operational Amplifier|{{http:// | ||
+ | | Crosspoint Switch | ||
| Switch Rotary Encoder | | Switch Rotary Encoder | ||
+ | | 5mm WS2812 LED |{{https:// | ||
| 5mm RGB LED | | 5mm RGB LED | ||
| Tactile Switch | | Tactile Switch | ||
Line 163: | Line 187: | ||
|Silicon 4x4 Button Matrix 5mm|[[https:// | |Silicon 4x4 Button Matrix 5mm|[[https:// | ||
|Silicon 4x4 Button Matrix 3mm|[[https:// | |Silicon 4x4 Button Matrix 3mm|[[https:// | ||
+ | | jack 3,5mm mono | ||
| Joystick 1 |[[https:// | | Joystick 1 |[[https:// | ||
| Joystick 2 |[[https:// | | Joystick 2 |[[https:// |
mb-modulbox-ng.txt · Last modified: 2016/10/08 12:53 by psykhaze
