phatline
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
phatline [2022/01/26 17:35] – [Contact] phatline | phatline [2023/09/07 19:50] (current) – phatline | ||
Line 18: | Line 18: | ||
=====Project list===== | =====Project list===== | ||
- | //Currently | + | //Actual// |
+ | **Triggermatrix 5 aka TM5:** | ||
+ | * [[Triggermatrix5]] Overview and Build Tutorial\\ | ||
+ | * [[TM5-GateInput]] Levelshifter 5V>3V and Preamp for Gate/ | ||
+ | * [[TM5-codeblock]] Menuesection\\ | ||
+ | * [[TM5-Gate-Board]] 3,5 Jack Boards for 16 + 16 Gates\\ | ||
+ | * [[TM5-DinDoutGate]] Module for UI and Gates for\\ | ||
+ | * [[Core4Disc]] CoreBoard for STM32F407VGT6 Discovery Boards, with some onboard Peripheral\\ | ||
+ | * [[Core4DiscMidiEx]] Midi-Expansion Board for Core4Disc\\ | ||
+ | * [[DisplayDriver-SMD]] Display Driver for 18x SSD1306 7Pin Displays\\ | ||
+ | * [[BLM16x16V2]] 16x16 Button Led Matrix | ||
+ | * [[TM5-Housing]] Alle Files, and Description for Panels - so you can source it on your own\\ | ||
+ | **Open PAD** | ||
+ | * [[OpenPAD]] First concept off using the MPD 226 Pads and Foil with custom PCB, with MIOS!\\ | ||
+ | * [[DoutX2DinX1]] SMD board with free Production Files- can be used for other project too.\\ | ||
+ | * [[OpenPAD-Codeblock]] Buttons and Encoder Board - in combination with [[DoutX2DinX1]] Free Files!\\ | ||
+ | * [[Core4OpenPAD]] A STM32F407VGT6 based Board - Pick and Place\\ | ||
+ | **DAW-Ableton** | ||
+ | * [[DAW-Ableton]] A DAW Controller for Ableton with a bunch of M4L sysex...\\ | ||
+ | * [[DAW-BTN]] 3+3 LED Buttons, a PCB tu build a DAW-Controller\\ | ||
+ | * [[DAW-Encoder-Display]] SSD1306 and Encoders, a PCB to build a DAW-Controller (scaleable)\\ | ||
+ | // paused projects: // | ||
+ | * [[MSQ-CC-LRE-V2]] Optimized for Eurorack, now with Displays - at the moment hardcodet for Nord Drum2\\ | ||
* [[Euro-Aout-NG-Connector-Board]] --- a Breakoutboard for the whell known Aout-NG-Dac-Board. | * [[Euro-Aout-NG-Connector-Board]] --- a Breakoutboard for the whell known Aout-NG-Dac-Board. | ||
* [[Euro-Midi-IO]] --- a Eurorack Sized 2IN 2THRU 2OUT Midi-IO-Board, | * [[Euro-Midi-IO]] --- a Eurorack Sized 2IN 2THRU 2OUT Midi-IO-Board, | ||
* [[LoopA-EuroRack-Panel]] --- a Eurorack Frontpanl + Breakoutoboard for Midiphy LoopA | * [[LoopA-EuroRack-Panel]] --- a Eurorack Frontpanl + Breakoutoboard for Midiphy LoopA | ||
* [[LRE-OLED-Bar]] --- PCB to hold SSD1306 Screens above fairlightiii´s[[mb-lre8x2cs_pcb]] inside Eurorack | * [[LRE-OLED-Bar]] --- PCB to hold SSD1306 Screens above fairlightiii´s[[mb-lre8x2cs_pcb]] inside Eurorack | ||
+ | * [[LRE-OLED-Bar2]] --- PCB to hold SSD1306 Screens above fairlightiii´s[[mb-lre8x2cs_pcb]] inside Eurorack ([[DisplayDriver-SMD]] is needet!) | ||
* [[SRIO-Router]] --- 1 UI, routed to 8 Cores | * [[SRIO-Router]] --- 1 UI, routed to 8 Cores | ||
* [[LRE5-LCD2]] --- 5 Ledrings, 5 Encoders, 2 1306er LCDs, 1 Button on 10x10cm (pick and place) | * [[LRE5-LCD2]] --- 5 Ledrings, 5 Encoders, 2 1306er LCDs, 1 Button on 10x10cm (pick and place) | ||
Line 39: | Line 65: | ||
+ | * [[CoilWinder]] Coil Winder, Mios-Based Tesla-Coil Winding machine | ||
* [[TriggerMatrix4]] TMV4 | * [[TriggerMatrix4]] TMV4 | ||
* [[TriggerMatrix]] TMV3 | * [[TriggerMatrix]] TMV3 | ||
* [[clock2audio2clock]] convert Midiclock 2 Audio, record this audio, play this audio convert 2 Midiclok, for Multitrack Audio Studios without Midi, in order to overdub a track that need to be in Midi-Clock-Sync, | * [[clock2audio2clock]] convert Midiclock 2 Audio, record this audio, play this audio convert 2 Midiclok, for Multitrack Audio Studios without Midi, in order to overdub a track that need to be in Midi-Clock-Sync, | ||
* [[MSQ-CC-BCR]] some kind of a synth programmer, but with CC-Motionsequencer, | * [[MSQ-CC-BCR]] some kind of a synth programmer, but with CC-Motionsequencer, | ||
- | * [[MSQ-CC-LRE]] same as MSQ-CC-BCR but, newer, faster, better... also hardcodet for Nord Drum2 | + | * [[MSQ-CC-LRE]] |
=====Contact===== | =====Contact===== | ||
triggermatrix@gmail.com\\ | triggermatrix@gmail.com\\ |
phatline.txt · Last modified: 2023/09/07 19:50 by phatline
