scs_pcb
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
scs_pcb [2016/09/26 09:34] – [Where to buy?] ilmenatorscs_pcb [2021/09/11 09:09] (current) – [Where to buy?] ilmenator
Line 1: Line 1:
 ====== MIDIbox SCS Standard Control Surface module ====== ====== MIDIbox SCS Standard Control Surface module ======
-The SCS module implements a standard user interface that is available as a module in the MIOS codebase. It goes nicely with a 20x character LCD and connects to J10 on the core board. An application example can be found in [[http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F027_scs%2F|tutorial #027]].+The SCS module implements a standard user interface that is available as a module in the MIOS codebase. It goes nicely with a 20x character LCD and connects to J10 on the core board. An application example can be found in [[https://github.com/midibox/mios32/tree/master/apps/tutorials/027_scs|tutorial #027]].
 The PCB I have designed can accommodate three different types of switches: my favourite switches from [[16x4blm_pcb|Marquardt (6425 series)]], TK's favourites from ITT Schadow (D6 series) available at Reichelt, and the [[16x4blm_pcb|E-Switch TL1100 series]] (see e.g. MB SEQv4) can be used. The PCB I have designed can accommodate three different types of switches: my favourite switches from [[16x4blm_pcb|Marquardt (6425 series)]], TK's favourites from ITT Schadow (D6 series) available at Reichelt, and the [[16x4blm_pcb|E-Switch TL1100 series]] (see e.g. MB SEQv4) can be used.
Line 18: Line 18:
 ==== Where to buy? ==== ==== Where to buy? ====
-If you are interested in buying this, send a personal message (PM) to user //ilmenator// over at the [[http://midibox.org/forums/|MIDIbox forum]] (you have to register to be able to send PM). As of September 2016, I have PCBs available for 4,50€ each.+If you are interested in buying this, send a personal message (PM) to user //ilmenator// over at the [[http://midibox.org/forums/|MIDIbox forum]] (you have to register to be able to send PM). As of September 2021, I have PCBs available for 4,50€ each.
 ===== Switches ===== ===== Switches =====
scs_pcb.txt · Last modified: 2021/09/11 09:09 by ilmenator
