seq_v4l_mk._ii
Differences
Link to this comparison view
Both sides previous revisionPrevious revision
Next revision
Previous revision
seq_v4l_mk._ii [2017/02/06 22:00] – [Firmware] latigid_onseq_v4l_mk._ii [2017/02/15 20:49] (current) – [Firmware] latigid_on
Line 156: Line 156:
 ==== Firmware ==== ==== Firmware ====
-{{:seqv4l:seq_v4l_.zip|}}+{{:seqv4l:firmware.zip|}}
 This file should be uploaded to an STM32F4 Core This file should be uploaded to an STM32F4 Core
-The config file MBSEQ_HW.V4L should be copied to the root of the SD Card used.+The config file MBSEQ_HW.V4L should be copied to the root of the SD Card used. [[http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fsequencers%2Fmidibox_seq_v4_lite%2Fhwcfg%2Fsrio_v4l%2F|It can be found on the SVN repository]].
 +At some point these should be made available in the normal MIOS32 download section.
 A sessions folder will be created on first use if one doesn't exist. If you're having trouble with the MIDI Input, please open the SESSIONS/DEF_V4L/MBSEQ_C.V4 file and change: A sessions folder will be created on first use if one doesn't exist. If you're having trouble with the MIDI Input, please open the SESSIONS/DEF_V4L/MBSEQ_C.V4 file and change:
seq_v4l_mk._ii.txt · Last modified: 2017/02/15 20:49 by latigid_on
