acmididefines
This page is part of the mios_c_simulator_-_debugger
ACSim_console.h
ACSim_console.c
ACSim_toolbox.h
ACSim_toolbox.c
ACMidiDefines.h
/* * ACMidiDefines.h * * Created by Michael Markert, audiocommander on 29.07.05 * Adapted to MIOS on 21.05.06. * Copyright 2006 Michael Markert, http://www.audiocommander.de * */ /* * Released under GNU General Public License * http://www.gnu.org/licenses/gpl.html * * This program is free software; you can redistribute it and/or modify it under the terms * of the GNU General Public License as published by the Free Software Foundation * * YOU ARE ALLOWED TO COPY AND CHANGE * BUT YOU MUST RELEASE THE SOURCE TOO (UNDER GNU GPL) IF YOU RELEASE YOUR PRODUCT * YOU ARE NOT ALLOWED NOT USE IT WITHIN PROPRIETARY CLOSED-SOURCE PROJECTS */ #ifndef _ACMIDIDEFINES_H #define _ACMIDIDEFINES_H // **************************** // // ** Channel Voice Messages ** // // **************************** // #ifdef _DEBUG_C #pragma mark - #pragma mark Channel Voice Messages #endif // MIDI_NOTE_OFF: 128..143 #define MIDI_NOTE_OFF 0x80 // MIDI_NOTE_ON: 144..159 #define MIDI_NOTE_ON 0x90 // MIDI_POLY_AFTER: 160..175 #define MIDI_POLY_AFTER 0xA0 // MIDI_CC: 176..191 #define MIDI_CC 0xB0 // MIDI_PRG: 192..207 #define MIDI_PRG 0xC0 // MIDI_CH_AFTER: 208..223 #define MIDI_CH_AFTER 0xD0 // MIDI_PITCH: 224..239 // Pitch value is 14bit (-8192..+8191) #define MIDI_PITCH 0xE0 // ****************************** // // ** Channel Control Messages ** // // ****************************** // #ifdef _DEBUG_C #pragma mark - #pragma mark Channel Control Messages #endif // MIDI_CC_BANK_SELECT 0 #define MIDI_CC_BANK_SELECT 0x00 // MIDI_CC_MODULATION 1 // MIDI_CC_BREATH 2 // MIDI_CC_FOOT 4 // MIDI_CC_PORTAMENTO 5 // MIDI_CC_DATA_ENTRY_MSB 6 // MIDI_CC_VOLUME 7 // MIDI_CC_BALANCE 8 // MIDI_CC_PAN 10 // MIDI_CC_EXPRESSION 11 // MIDI_CC_FX1 12 // MIDI_CC_FX2 13 #define MIDI_CC_MODULATION 0x01 #define MIDI_CC_BREATH 0x02 #define MIDI_CC_FOOT 0x04 #define MIDI_CC_PORTAMENTO 0x05 #define MIDI_CC_DATA_ENTRY_MSB 0x06 #define MIDI_CC_VOLUME 0x07 #define MIDI_CC_BALANCE 0x08 #define MIDI_CC_PAN 0x0A #define MIDI_CC_EXPRESSION 0x0B #define MIDI_CC_FX1 0x0C #define MIDI_CC_FX2 0x0D // 14..31 undefined & general purpose // 32..63 LSB MODES: (Byte b = LSByte - 32) // MIDI_CC_BANK_SELECT_LSB 32 // MIDI_CC_MODULATION_LSB 33 // MIDI_CC_BREATH_LSB 34 // MIDI_CC_FOOT_LSB 36 // MIDI_CC_PORTAMENTO_LSB 37 // MIDI_CC_DATA_ENTRY_LSB 38 // MIDI_CC_VOLUME_LSB 39 // MIDI_CC_BALANCE_LSB 40 // MIDI_CC_PAN_LSB 42 // MIDI_CC_EXPRESSION_LSB 43 // MIDI_CC_FX1_LSB 44 // MIDI_CC_FX2_LSB 45 #define MIDI_CC_BANK_SELECT_LSB 0x20 #define MIDI_CC_MODULATION_LSB 0x21 #define MIDI_CC_BREATH_LSB 0x22 #define MIDI_CC_FOOT_LSB 0x24 #define MIDI_CC_PORTAMENTO_LSB 0x25 #define MIDI_CC_DATA_ENTRY_LSB 0x26 #define MIDI_CC_VOLUME_LSB 0x27 #define MIDI_CC_BALANCE_LSB 0x28 #define MIDI_CC_PAN_LSB 0x2A #define MIDI_CC_EXPRESSION_LSB 0x2B #define MIDI_CC_FX1_LSB 0x2C #define MIDI_CC_FX2_LSB 0x2D #ifdef _DEBUG_C #pragma mark - #endif // ________ < 63 off, > 64 on ________ // MIDI_CC_PEDAL (=SUSTAIN) 64 // MIDI_CC_PORTAMENTO_ONOFF 65 // MIDI_CC_SUSTENUTO 66 // MIDI_CC_SOFT_PEDAL 67 // MIDI_CC_LEGATO 68 // MIDI_CC_HOLD 69 #define MIDI_CC_PEDAL 0x40 #define MIDI_CC_PORTAMENTO_ONOFF 0x41 #define MIDI_CC_SUSTENUTO 0x42 #define MIDI_CC_SOFT_PEDAL 0x43 #define MIDI_CC_LEGATO 0x44 #define MIDI_CC_HOLD 0x45 #ifdef _DEBUG_C #pragma mark - #endif // ______ LSB Sound Controllers ______ // MIDI_CC_VARIATION 70 // MIDI_CC_TIMBRE 71 // MIDI_CC_RELEASE 72 // MIDI_CC_ATTACK 73 // MIDI_CC_BRIGHTNESS 74 // MIDI_CC_DECAY 75 // MIDI_CC_VIBRATO_RATE 76 // MIDI_CC_VIBRATO_DEPTH 77 // MIDI_CC_VIBRATO_DELAY 78 #define MIDI_CC_VARIATION 0x46 #define MIDI_CC_TIMBRE 0x47 #define MIDI_CC_RELEASE 0x48 #define MIDI_CC_ATTACK 0x49 #define MIDI_CC_BRIGHTNESS 0x4A #define MIDI_CC_DECAY 0x4B #define MIDI_CC_VIBRATO_RATE 0x4C #define MIDI_CC_VIBRATO_DEPTH 0x4D #define MIDI_CC_VIBRATO_DELAY 0x4E // MIDI_CC_FX1_DEPTH 91 // MIDI_CC_FX2_DEPTH 92 // MIDI_CC_FX3_DEPTH 93 // MIDI_CC_FX4_DEPTH 94 // MIDI_CC_FX5_DEPTH 95 #define MIDI_CC_FX1_DEPTH 0x5B #define MIDI_CC_FX2_DEPTH 0x5C #define MIDI_CC_FX3_DEPTH 0x5D #define MIDI_CC_FX4_DEPTH 0x5E #define MIDI_CC_FX5_DEPTH 0x5F #ifdef _DEBUG_C #pragma mark - #endif // ______ Registered Parameters ______ // MIDI_CC_DATA_INCREMENT 96 // MIDI_CC_DATA_DECREMENT 97 // MIDI_CC_NRPN_LSB 98 // MIDI_CC_NRPN_MSB 99 // MIDI_CC_RPN_LSB 100 // MIDI_CC_RPN_MSB 101 #define MIDI_CC_DATA_INCREMENT 0x60 #define MIDI_CC_DATA_DECREMENT 0x61 #define MIDI_CC_NRPN_LSB 0x62 #define MIDI_CC_NRPN_MSB 0x63 #define MIDI_CC_RPN_LSB 0x64 #define MIDI_CC_RPN_MSB 0x65 // 102..119 Undefined #ifdef _DEBUG_C #pragma mark - #endif // _______ Channel Controllers _______ // MIDI_CC_ALL_SOUND_OFF 120 // MIDI_CC_RESET 121 // MIDI_CC_LOCAL 122 // MIDI_CC_ALL_NOTES_OFF 123 // MIDI_CC_OMNI_OFF 124 // MIDI_CC_OMNI_ON 125 // MIDI_CC_POLY_ONOFF 126 // MIDI_CC_POLY_ON 127 #define MIDI_CC_ALL_SOUND_OFF 0x78 #define MIDI_CC_RESET 0x79 #define MIDI_CC_LOCAL 0x7A #define MIDI_CC_ALL_NOTES_OFF 0x7B #define MIDI_CC_OMNI_OFF 0x7C #define MIDI_CC_OMNI_ON 0x7D #define MIDI_CC_POLY_ONOFF 0x7E #define MIDI_CC_POLY_ON 0x7F // **************************** // // ** System Common Messages ** // // **************************** // #ifdef _DEBUG_C #pragma mark - #pragma mark System Common Messages #endif // MIDI_SYSEX: 240 #define MIDI_SYSEX 0xF0 // MIDI_TIMECODE: 241 // MIDI_SONG_POSITION_POINTER 242 // MIDI_SONG_SELECT 243 // MIDI_TUNE_REQUEST 246 // MIDI_EOX (END OF SYSEX) 247 #define MIDI_TIMECODE 0xF1 #define MIDI_SONG_POSITION_POINTER 0xF2 #define MIDI_SONG_SELECT 0xF3 #define MIDI_TUNE_REQUEST 0xF6 #define MIDI_EOX 0xF7 // ******************************* // // ** System Real-Time Messages ** // // ******************************* // #ifdef _DEBUG_C #pragma mark - #pragma mark System Real-Time Messages #endif // MIDI_CLOCK 248 #define MIDI_CLOCK 0xF8 // MIDI_START 250 // MIDI_CONTINUE 251 // MIDI_STOP 252 // MIDI_ACTIVE_SENSING 254 // MIDI_RESET 255 #define MIDI_START 0xFA #define MIDI_CONTINUE 0xFB #define MIDI_STOP 0xFC #define MIDI_ACTIVE_SENSING 0xFE #define MIDI_RESET 0xFF // ****************** // // ** NOTE LENGHTS ** // // ****************** // #ifdef _DEBUG_C #pragma mark - #pragma mark Note Lengths #endif #define MIDI_NOTE_LENGTH_0 0 #define MIDI_NOTE_LENGTH_1 96 #define MIDI_NOTE_LENGTH_2 48 #define MIDI_NOTE_LENGTH_3 36 #define MIDI_NOTE_LENGTH_4 24 #define MIDI_NOTE_LENGTH_6 18 #define MIDI_NOTE_LENGTH_8 12 #define MIDI_NOTE_LENGTH_12 9 #define MIDI_NOTE_LENGTH_16 6 #define MIDI_NOTE_LENGTH_32 3 // **************************** // // ** BASE NOTES FOR HARMONY ** // // **************************** // #ifdef _DEBUG_C #pragma mark - #pragma mark Base Notes #endif #define MIDI_NOTE_C 0 #define MIDI_NOTE_CIS 1 #define MIDI_NOTE_D 2 #define MIDI_NOTE_DIS 3 #define MIDI_NOTE_E 4 #define MIDI_NOTE_F 5 #define MIDI_NOTE_FIS 6 #define MIDI_NOTE_G 7 #define MIDI_NOTE_GIS 8 #define MIDI_NOTE_A 9 #define MIDI_NOTE_AIS 10 #define MIDI_NOTE_H 11 // **************************** // // ** NOTE 2 FREQUENCY TABLE ** // // **************************** // #ifdef _DEBUG_C #pragma mark - #pragma mark Note2Freq Table #endif // FREQUENCY (in Hertz) = 440 * 2 ^ ( (OCTAVE - 4) + ((TON - 10) / 12) ) // octave -5 #define MIDI_NOTE_0_FREQ 8 // 8.1757989156 -6900.00 #define MIDI_NOTE_1_FREQ 9 // 8.6619572180 -6800.00 #define MIDI_NOTE_2_FREQ 9 // 9.1770239974 -6700.00 #define MIDI_NOTE_3_FREQ 10 // 9.7227182413 -6600.00 #define MIDI_NOTE_4_FREQ 10 // 10.3008611535 -6500.00 #define MIDI_NOTE_5_FREQ 11 // 10.9133822323 -6400.00 #define MIDI_NOTE_6_FREQ 12 // 11.5623257097 -6300.00 #define MIDI_NOTE_7_FREQ 12 // 12.2498573744 -6200.00 #define MIDI_NOTE_8_FREQ 13 // 12.9782717994 -6100.00 #define MIDI_NOTE_9_FREQ 13 // 13.7500000000 -6000.00 #define MIDI_NOTE_10_FREQ 15 // 14.5676175474 -5900.00 #define MIDI_NOTE_11_FREQ 15 // 15.4338531643 -5800.00 // octave -4 #define MIDI_NOTE_12_FREQ 16 // 16.3515978313 -5700.00 #define MIDI_NOTE_13_FREQ 17 // 17.3239144361 -5600.00 #define MIDI_NOTE_14_FREQ 18 // 18.3540479948 -5500.00 #define MIDI_NOTE_15_FREQ 19 // 19.4454364826 -5400.00 #define MIDI_NOTE_16_FREQ 21 // 20.6017223071 -5300.00 #define MIDI_NOTE_17_FREQ 22 // 21.8267644646 -5200.00 #define MIDI_NOTE_18_FREQ 23 // 23.1246514195 -5100.00 #define MIDI_NOTE_19_FREQ 24 // 24.4997147489 -5000.00 #define MIDI_NOTE_20_FREQ 26 // 25.9565435987 -4900.00 #define MIDI_NOTE_21_FREQ 27 // 27.5000000000 -4800.00 #define MIDI_NOTE_22_FREQ 29 // 29.1352350949 -4700.00 #define MIDI_NOTE_23_FREQ 31 // 30.8677063285 -4600.00 // octave -3 #define MIDI_NOTE_24_FREQ 33 // 32.7031956626 -4500.00 #define MIDI_NOTE_25_FREQ 35 // 34.6478288721 -4400.00 #define MIDI_NOTE_26_FREQ 37 // 36.7080959897 -4300.00 #define MIDI_NOTE_27_FREQ 39 // 38.8908729653 -4200.00 #define MIDI_NOTE_28_FREQ 41 // 41.2034446141 -4100.00 #define MIDI_NOTE_29_FREQ 44 // 43.6535289291 -4000.00 #define MIDI_NOTE_30_FREQ 46 // 46.2493028390 -3900.00 #define MIDI_NOTE_31_FREQ 49 // 48.9994294977 -3800.00 #define MIDI_NOTE_32_FREQ 52 // 51.9130871975 -3700.00 #define MIDI_NOTE_33_FREQ 55 // 55.0000000000 -3600.00 #define MIDI_NOTE_34_FREQ 58 // 58.2704701898 -3500.00 #define MIDI_NOTE_35_FREQ 62 // 61.7354126570 -3400.00 // octave -2 #define MIDI_NOTE_36_FREQ 65 // 65.4063913251 -3300.00 #define MIDI_NOTE_37_FREQ 69 // 69.2956577442 -3200.00 #define MIDI_NOTE_38_FREQ 73 // 73.4161919794 -3100.00 #define MIDI_NOTE_39_FREQ 78 // 77.7817459305 -3000.00 #define MIDI_NOTE_40_FREQ 82 // 82.4068892282 -2900.00 #define MIDI_NOTE_41_FREQ 87 // 87.3070578583 -2800.00 #define MIDI_NOTE_42_FREQ 92 // 92.4986056779 -2700.00 #define MIDI_NOTE_43_FREQ 98 // 97.9988589954 -2600.00 #define MIDI_NOTE_44_FREQ 104 // 103.8261743950 -2500.00 #define MIDI_NOTE_45_FREQ 110 // 110.0000000000 -2400.00 #define MIDI_NOTE_46_FREQ 116 // 116.5409403795 -2300.00 #define MIDI_NOTE_47_FREQ 123 // 123.4708253140 -2200.00 // octave -1 #define MIDI_NOTE_48_FREQ 131 // 130.8127826503 -2100.00 #define MIDI_NOTE_49_FREQ 139 // 138.5913154884 -2000.00 #define MIDI_NOTE_50_FREQ 147 // 146.8323839587 -1900.00 #define MIDI_NOTE_51_FREQ 156 // 155.5634918610 -1800.00 #define MIDI_NOTE_52_FREQ 165 // 164.8137784564 -1700.00 #define MIDI_NOTE_53_FREQ 175 // 174.6141157165 -1600.00 #define MIDI_NOTE_54_FREQ 185 // 184.9972113558 -1500.00 #define MIDI_NOTE_55_FREQ 196 // 195.9977179909 -1400.00 #define MIDI_NOTE_56_FREQ 208 // 207.6523487900 -1300.00 #define MIDI_NOTE_57_FREQ 220 // 220.0000000000 -1200.00 #define MIDI_NOTE_58_FREQ 233 // 233.0818807590 -1100.00 #define MIDI_NOTE_59_FREQ 247 // 246.9416506281 -1000.00 // octave 0 #define MIDI_NOTE_60_FREQ 262 // 261.6255653006 -900.00 #define MIDI_NOTE_61_FREQ 277 // 277.1826309769 -800.00 #define MIDI_NOTE_62_FREQ 294 // 293.6647679174 -700.00 #define MIDI_NOTE_63_FREQ 311 // 311.1269837221 -600.00 #define MIDI_NOTE_64_FREQ 330 // 329.6275569129 -500.00 #define MIDI_NOTE_65_FREQ 349 // 349.2282314330 -400.00 #define MIDI_NOTE_66_FREQ 370 // 369.9944227116 -300.00 #define MIDI_NOTE_67_FREQ 392 // 391.9954359817 -200.00 #define MIDI_NOTE_68_FREQ 415 // 415.3046975799 -100.00 #define MIDI_NOTE_69_FREQ 440 // 440.0000000000 0.00 #define MIDI_NOTE_70_FREQ 466 // 466.1637615181 100.00 #define MIDI_NOTE_71_FREQ 494 // 493.8833012561 200.00 // octave 1 #define MIDI_NOTE_72_FREQ 523 // 523.2511306012 300.00 #define MIDI_NOTE_73_FREQ 554 // 554.3652619537 400.00 #define MIDI_NOTE_74_FREQ 587 // 587.3295358348 500.00 #define MIDI_NOTE_75_FREQ 622 // 622.2539674442 600.00 #define MIDI_NOTE_76_FREQ 659 // 659.2551138257 700.00 #define MIDI_NOTE_77_FREQ 698 // 698.4564628660 800.00 #define MIDI_NOTE_78_FREQ 740 // 739.9888454233 900.00 #define MIDI_NOTE_79_FREQ 784 // 783.9908719635 1000.00 #define MIDI_NOTE_80_FREQ 831 // 830.6093951599 1100.00 #define MIDI_NOTE_81_FREQ 880 // 880.0000000000 1200.00 #define MIDI_NOTE_82_FREQ 932 // 932.3275230362 1300.00 #define MIDI_NOTE_83_FREQ 988 // 987.7666025122 1400.00 // octave 2 #define MIDI_NOTE_84_FREQ 1046 // 1046.5022612024 1500.00 #define MIDI_NOTE_85_FREQ 1109 // 1108.7305239075 1600.00 #define MIDI_NOTE_86_FREQ 1175 // 1174.6590716696 1700.00 #define MIDI_NOTE_87_FREQ 1244 // 1244.5079348883 1800.00 #define MIDI_NOTE_88_FREQ 1318 // 1318.5102276515 1900.00 #define MIDI_NOTE_89_FREQ 1397 // 1396.9129257320 2000.00 #define MIDI_NOTE_90_FREQ 1480 // 1479.9776908465 2100.00 #define MIDI_NOTE_91_FREQ 1568 // 1567.9817439270 2200.00 #define MIDI_NOTE_92_FREQ 1661 // 1661.2187903198 2300.00 #define MIDI_NOTE_93_FREQ 1760 // 1760.0000000000 2400.00 #define MIDI_NOTE_94_FREQ 1865 // 1864.6550460724 2500.00 #define MIDI_NOTE_95_FREQ 1975 // 1975.5332050245 2600.00 // octave 3 #define MIDI_NOTE_96_FREQ 2093 // 2093.0045224048 2700.00 #define MIDI_NOTE_97_FREQ 2217 // 2217.4610478150 2800.00 #define MIDI_NOTE_98_FREQ 2349 // 2349.3181433393 2900.00 #define MIDI_NOTE_99_FREQ 2489 // 2489.0158697766 3000.00 #define MIDI_NOTE_100_FREQ 2637 // 2637.0204553030 3100.00 #define MIDI_NOTE_101_FREQ 2794 // 2793.8258514640 3200.00 #define MIDI_NOTE_102_FREQ 2960 // 2959.9553816931 3300.00 #define MIDI_NOTE_103_FREQ 3136 // 3135.9634878540 3400.00 #define MIDI_NOTE_104_FREQ 3322 // 3322.4375806396 3500.00 #define MIDI_NOTE_105_FREQ 3520 // 3520.0000000000 3600.00 #define MIDI_NOTE_106_FREQ 3729 // 3729.3100921447 3700.00 #define MIDI_NOTE_107_FREQ 3951 // 3951.0664100490 3800.00 // octave 4 #define MIDI_NOTE_108_FREQ 4186 // 4186.0090448096 3900.00 #define MIDI_NOTE_109_FREQ 4435 // 4434.9220956300 4000.00 #define MIDI_NOTE_110_FREQ 4699 // 4698.6362866785 4100.00 #define MIDI_NOTE_111_FREQ 4978 // 4978.0317395533 4200.00 #define MIDI_NOTE_112_FREQ 5274 // 5274.0409106059 4300.00 #define MIDI_NOTE_113_FREQ 5588 // 5587.6517029281 4400.00 #define MIDI_NOTE_114_FREQ 5920 // 5919.9107633862 4500.00 #define MIDI_NOTE_115_FREQ 6272 // 6271.9269757080 4600.00 #define MIDI_NOTE_116_FREQ 6645 // 6644.8751612791 4700.00 #define MIDI_NOTE_117_FREQ 7040 // 7040.0000000000 4800.00 #define MIDI_NOTE_118_FREQ 7459 // 7458.6201842894 4900.00 #define MIDI_NOTE_119_FREQ 7902 // 7902.1328200980 5000.00 // octave 5 #define MIDI_NOTE_120_FREQ 8372 // 8372.0180896192 5100.00 #define MIDI_NOTE_121_FREQ 8870 // 8869.8441912599 5200.00 #define MIDI_NOTE_122_FREQ 9397 // 9397.2725733570 5300.00 #define MIDI_NOTE_123_FREQ 9956 // 9956.0634791066 5400.00 #define MIDI_NOTE_124_FREQ 10548 // 10548.0818212118 5500.00 #define MIDI_NOTE_125_FREQ 11175 // 11175.3034058561 5600.00 #define MIDI_NOTE_126_FREQ 11840 // 11839.8215267723 5700.00 #define MIDI_NOTE_127_FREQ 12544 // 12543.8539514160 5800.00 #endif /* _ACMIDIDEFINES_H */
acmididefines.txt · Last modified: 2007/09/30 06:36 by 127.0.0.1
