AC Sensorizer sensorizes up to 8 sensors and interpolates its AIN-readings. The main target of this application are sensory devices delivering not exactly 0 - 5 V, like pressure-, distance-, resistor-based sensors or softPots.
These two videos show the ACSensorizer 0.2 which is using an outdated HUI, but nevertheless the concept of the Sensorizer is demonstrated quite well:
The ACSensorizer has been developed by Audiocommander ( http://www.audiocommander.de )
© 2007 Michael Markert
This software is released under a GNU License. You are not allowed to use this software or parts of it in closed-source projects! Please notice that due to the licenses for MBHP and MIOS you may only use the Hard- and Software for private purposes. Non-commercial use only!
Please contribute and name the author(s)!
MBHP Modules:
Sensors:
It is possible to use the sensorizer with only one Core Module. For these purposes a MAC OS X program is included to simulate encoders and buttons. You can easily test the application with one core module!
Version History
Compiling Notes
The application can be recompiled with a variety of strictly separated #define- options. For example setting SENSORIZER_INTERFACE_HUI to 0 compiles the application without hardware input controls and therefore reduces the file- and application space. Compiling without HUI, BANKSTICK, NRPN-Config and LCD generates code with approx. 3 or 4 pages; compiling with all options will result in an application file of 19 pages.
The Sensorizer provides:
Front Side | ||
Top | Left Encoder | current sensor selector (1..8) |
Right Encoder | Menu Selection Wheel | |
Bottom | White Button | PANIC |
Green Button | LOAD PATCH | |
Red Button | STORE PATCH | |
Left Encoder | Value setter for selected menu item / parameter 1 | |
Right Encoder | Value setter for selected menu item / parameter 2 | |
Black Button | PEDAL (2nd pedal connector at the rear) |
Back Side | |||
Left | 8 6-pin Mini-DIN connectors | For up to 8 Sensors | Connector Type can be changed! |
Middle | 5-pin DIN connectors | Midi-In and Midi-Out | |
Middle Center | 6.5mm Jack | External Foot-Pedal | A pedal is highly recommended! |
Right Top | Switch | ON/OFF Switch | |
Right Bottom | DC Connector | +9V DC Power Supply | Connector Type can be changed! |
The Interface is clearly structured; the encoders control the values on the screen next to them. A minimum set of additional buttons allow loading and saving of patches, sending PANIC! and an alternative pedal knob (it is recommended to add a second pedal on the backside. MIDI pedals (like Sustenuto or Pedal are of course also supported.
The following picture contains an overview of the onscreen LCD-menu structure. Click to view larger version:
See below which MIDI messages are recognized and sent by ACSensorizer:
Message Type | Received | Sent | Notes |
NOTE ON | x | x | Harmonized |
NOTE OFF | x | x | Harmonized |
POLY AFTERTOUCH | - | - | |
CC | x | x | See CC Message Table |
PROGRAM CHANGE | G | G | Global Channel only |
CHANNEL AFTERTOUCH | - | - | |
PITCH WHEEL | - | - |
Table A: MIDI Messages Implementation Chart
CC | Name | Received | Sent | Notes |
0-127 | see below | x | ||
0 | Bank Select | G | G | Global Channel only! |
6 | Data MSB | x | x | See NRPN Table D |
38 | Data LSB | x | x | See NRPN Table D |
64 | Pedal | x | x | Pedal |
66 | Sostenuto | x | x | Pedal |
67 | SoftPedal | x | x | Pedal |
80 | Harmony Base | x | x | Harmony (ACMidiProtocol) |
81 | Harmony Scale | x | x | 0..20 |
82 | Harmony Base Listen | x | x | <> 63 |
83 | Harmony Scale Previous | x | x | > 63 |
84 | Harmony Scale Next | x | x | > 63 |
85 | Harmony Random | x | x | > 63 |
87 | Quantize BPM | x | x | BPM = [0..127] + 60 |
98 | NRPN LSB | x | x | See NRPN Table C |
99 | NRPN MSB | x | x | See NRPN Table C |
Table B: Controller Change Implementation Chart
x YES
– NO
G Global Channel only
The channel numbers that are counted from 1 to 16 appear as 0 to 15 in code!
For more information on ACMidiProtocol supporting interchangeable notifications on BPM, Harmony and Scale changes, see ACMidiProtocol.h!
NRPN Controls
All Sensorizer parameters can be controlled and set by sending NRPN messages by MIDI:
NRPN MSB | |||
CC | Value | Control Type | Note |
CC99, 0x63 | 0x00..0x07 | Sensor 0..7 | LBS 98, See Table B |
CC99, 0x63 | 0x60 | Sensor Wheel | LSB 98, 0..8 |
CC99, 0x63 | 0x61 | Menu Wheel | LSB 98, 0..10 |
CC99, 0x63 | 0x62 | Param Wheel A | LSB 98, 0..127 |
CC99, 0x63 | 0x63 | Param Wheel B | LSB 98, 0..127 |
Table C: Control Types
NRPN LSB | DATA ENTRY MSB/LSB | ||||
CC | Value | Control Parameter | CC | Value | Description |
CC98, 0x62 | 0x00 | enabled | CC38, 0x26 | 0/1 | ON/OFF |
CC98, 0x62 | 0x01 | pedalMode | CC38, 0x26 | 0..7 | FILTER/HOLD/PANIC/KOMBI |
CC98, 0x62 | 0x02 | autoSense | CC38, 0x26 | 0..2 | AUTOSENSE_OFF/_MIN/_MAX |
CC98, 0x62 | 0x03 | invert | CC38, 0x26 | 0/1 | 0..127 or 127..0 |
CC98, 0x62 | 0x04 | releaseDetect | CC38, 0x26 | 0/1 | send 0 on release |
CC98, 0x62 | 0x10 | slowdown | CC38, 0x26 | 0..127 | drop AIN notifications |
CC98, 0x62 | 0x11 | sense_min | CC38, 0x26 & CC6, 0x6 | 0..1023 | drop below and set sense minimum |
CC98, 0x62 | 0x12 | sense_max | CC38, 0x26 & CC6, 0x6 | 0..1023 | drop above and set sense maximum |
CC98, 0x62 | 0x13 | sense_factor | CC38, 0x26 | 0..64 | f=(range/127) |
CC98, 0x62 | 0x21 | scale_from | CC38, 0x26 | 0..127 | restrict and rescale output |
CC98, 0x62 | 0x22 | scale_to | CC38, 0x26 | 0..127 | restrict and rescale output |
CC98, 0x62 | 0x70 | CH | CC38, 0x26 | 0..15 | MIDI Channel of sensor |
CC98, 0x62 | 0x71 | CC | CC38, 0x26 | 0..127 | MIDI Controller Change Number of sensor |
Table D: Control Parameters
Examples:
Turning the Menu Wheel (virtually):
Setting the CC to send for (already selected) sensor 1:
ACSensorizer supports writing and reading to 24LC256-type banksticks.
Each patch consists of 2 pages à 64 bytes ⇒ 128 bytes
2 banks with 128 patches each are available per 1 connected bankstick (24LC256)
Choose the appropriate bank by sending a Coarse-Adjust Bankselect (CC#0).
In HUI-Mode, switching a bank on the device also sends the current Bank/PRG.
Memory-map of one patch:
Data | Size in Bytes = Sum | Page | Address |
Version | 1 = 1 | 1 @ 0x00 | 0 @ 0x00 |
PatchName | 8 = 9 | 1 | 1 @ 0x01 |
<reserved> | 7 = 16 | 1 | 10 @ 0x0A |
BPM | 1 = 17 | 1 | 16 @ 0x10 |
<reserved> | 5 = 22 | 1 | 17 @ 0x11 |
harmony_base | 1 = 23 | 1 | 22 @ 0x16 |
harmony_scale | 1 = 24 | 1 | 23 @ 0x17 |
sensor[8] | 8 = 32 | 1 | 24 @ 0x18 |
CH[8] | 8 = 40 | 1 | 32 @ 0x20 |
CC[8] | 8 = 48 | 1 | 40 @ 0x28 |
sync_1[8] | 8 = 56 | 1 | 48 @ 0x30 |
<reserved> | 8 = 64 | 1 | 56 @ 0x38 |
slowdown[8] | 8 = 8 | 2 @ 0x40 | 0 @ 0x00 |
sense_factor[8] | 8 = 16 | 2 | 8 |
sens_min[8].MSB | 8 = 24 | 2 | 16 @ 0x10 |
sens_min[8].LSB | 8 = 32 | 2 | 24 |
sens_max[8].MSB | 8 = 40 | 2 | 32 @ 0x20 |
sens_max[8].LSB | 8 = 48 | 2 | 40 |
scale_from[8] | 8 = 56 | 2 | 48 @ 0x30 |
scale_to[8] | 8 = 64 | 2 | 56 |
Table E: Bankstick Patch Content
Patch addresses are: (patch * 0x80)
or PIC-optimized: (unsigned int)patch « 7
Example hex-output of patch#0 for Sensorizer > 0.4.0:
**MIOS_BANKSTICK_WritePage at 0x0 0: 04 44 65 66 61 75 6c 74 00 ff 00 00 00 00 00 00 .Default........ 16: 78 00 00 00 00 00 00 14 81 81 81 81 00 00 00 00 x............... 32: 00 00 00 00 00 00 00 00 14 15 16 17 18 19 1a 1b ................ 48: 08 08 08 08 08 08 08 08 00 00 00 00 00 00 00 00 ................ **MIOS_BANKSTICK_WritePage at 0x40 0: 02 02 02 02 02 02 02 02 04 04 04 04 04 04 04 04 ................ 16: 00 00 00 00 00 00 00 00 40 40 40 40 40 40 40 40 ........@@@@@@@@ 32: 03 03 03 03 03 03 03 03 70 70 70 70 70 70 70 70 ........pppppppp 48: 00 00 00 00 00 00 00 00 7f 7f 7f 7f 7f 7f 7f 7f ................
A reference to the last active patch (bank/prg) is stored in EEPROM to enable reloading on next startup. each time a patch is successfully loaded or stored the reference is automatically saved.
The available EEPROM adress range is from 0xF00000 to 0xF000FF (256 bytes):
EEPROM Address | Data | Size (bytes) |
0x00 - 0x01 | last bank | 1 byte |
0x01 - 0x02 | last patch | 1 byte |
0x02 - 0xFF | <reserved> | 254 bytes |
Table F: EEPROM Content
1. MBHP Core
Follow the instructions at http://www.ucapps.de/mbhp_core.html. Don't forget to add MIDI-Cables and a 9V/800mA Power Supply!
2. MBHP LCD
Follow the instructions for a 2×16 LCD at http://www.ucapps.de/mbhp_lcd.html
3. MBHP DIN
Follow the instructions at http://www.ucapps.de/mbhp_din.html
4. MBHP DOUT
(optional) If you have lights on your Sensors, you can add a DOUT module: http://www.ucapps.de/mbhp_dout.html
5. MBHP Bankstick
Follow the instructions at http://www.ucapps.de/mbhp_bankstick.html. I'm using the Bankstick PCB supporting up to 8 Banksticks; maybe one Bankstick is sufficient for you (1 BS provides two banks with 127 patches each = 256 patches per Bankstick).
6. AIN “Breakout Board”
I use to solder extra 3-pin connectors on a seperate PCB. These pins allow quick grounding with a jumper or to switch the sensors easily to check for hardware errors. And it's a lot smarter to assemble the case without having to desolder all connections ;)
7. AIN Cables
I'm using 6-pin Mini-DIN connectors. In theory, a three-pin connection would be sufficient, but with a 6-pin cable, I can use 2 pins for an external voltage supply or additional DIN/DOUT lines.
8. Encoders and Buttons
9. DIN Connections
Connect the Encoders and Buttons as shown on the following table. The DIN module has to be connected to J9 of core module (see din_module for connection diagram with SmashTV Core modules.
The following image is the upper view of a DIN-Board from Smash TV, check this PDF if you are using the "standard" design from ucapps (just note the name of the pins - D0,D1, D2, etc…):
10. DOUT Connection
(optional) Connect the Dout Pin #1 to a LED that sits in Sensor #1 (#2 to #2, #3 to #3 and so on…).
11. Upload MIOS
I'm running it with MIOS8 (PIC) 1.9e, but it should work with any newer 8-bit version. An update to the new app-structure is planned. See Downloads… and MIOS8 Upload for Newbies
12. Upload ACSensorizer
Upload “ACSensorizer.hex” /-OR-/ “ACSensorizer.syx” (depending on the method you are using… ⇒ see “Uploading an Application” at MIOS8 Upload for Newbies)
13. Sensor Calibration
Done!
This site is about to change while the Sensorizer is beeing developed further!
have fun! – audiocommander
