bandmaster
BANDMASTER
MIDI Routing System and Control Surface.
Scalable MIDI Routing application using the MCAN and the M16 Interface…
Bandmaster CS
The Remote Control.
Top
Bottom
BOM
Mouser BOM version 1. to complete
| Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | Other | Notes |
| Resistors | ||||||||
| 4 | 22R 5% | 0603 | R1, R2, R3, R4 | 667-ERJ-PA3J220V | ||||
| 1 | 120R 1% | 1206 | R9 | 71-CRCW1206120RFKEAC | ||||
| 8 | 220R 5% | 0603 | R17, R18, R19, R20, R21, R22, R23, R24 | 755-ESR03EZPJ221 | ||||
| 1 | 470R 5% | 0603 | R7 | 755-ESR03EZPJ471 | ||||
| 3 | 680R 5% | 0603 | R5, R12, R13 | 667-ERJ-PA3J681V | Depends on Led | |||
| 5 | 10K 5% | 0603 | R6, R8, R14, R15, R16 | 755-ESR03EZPJ103 | ||||
| 2 | 100K 5% | 0603 | R10, R11 | 755-ESR03EZPJ104 | ||||
| Resistors Network | ||||||||
| 3 | 10K 5% | DIL5 | RN1, RN2, RN3 | 858-L051S103LF | ||||
| Capacitors | ||||||||
| 9 | 100n | 0603 | C2, C4, C6, C9, C10, C12, C13, C14, C15 | 80-C0603C104Z3V | ||||
| 2 | 1u | 1210 | C3, C5 | 710-885012209003 | ||||
| 4 | 4,7u Tantalum | SMC_A(1206) | C1, C7, C8, C11 | 647-F931C475MAA | ||||
| ESD Suppressors / TVS Diodes | ||||||||
| 4 | CG0603MLC-05E | 0603 | Z1, Z2, Z3, Z4 | 652-CG0603MLC-05E | ||||
| 1 | PESD1CAN | SOT23 | Z5 | 771-PESD1CAN-T/R | ||||
| Ferrite Bead | ||||||||
| 1 | BLM21 | 0805 | L1 | 81-BLM21P331SG | ||||
| Diodes | ||||||||
| 51 | 1N4148WS | SOD323-W | D1, D2, D3, D4, D5, D6, D7, D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21, D22, D23, D24, D25, D26, D27, D28, D29, D30, D31, D32, D33, D34, D35, D36, D37, D38, D39, D40, D41, D42, D43, D44, D45, D46, D47, D48, D49, D50, D51 | 512-1N4148WS | Only if you use CAN without transceiver | |||
| LEDs | ||||||||
| 3 | – | THT | LED1, LED2, LED_OC | 2x5mm rectangular THT | ||||
| OLED Screen | ||||||||
| 1 | ER-OLEDM032-1W | OLED | ER-OLEDM032-1W | buydisplay SSD1322 | ||||
| IC | ||||||||
| 1 | TPS2113APWR | SOT23-5L | IC1 | 595-TPS2113APWR | Power Switch IC | |||
| 1 | STMPS2161STR | SOT23-5L | IC2 | 511-STMPS2161STR | Power Switch IC | |||
| 1 | TCAN1042GV | SOIC8 | IC3 | 595-TCAN1042GVDRQ1 | CAN tranceiver | |||
| 2 | 74HC595 | TSSOP-16 | IC4, IC5 | 595-SN74HC595PWR | ||||
| 2 | 74HC165 | TSSOP-16 | IC6, IC7 | 595-SN74HC165PWR | ||||
| Switches and Encoder | ||||||||
| 2 | B3F-31xx | – | USER, RESET | 653-B3F-3122 | ||||
| 53 | MEC_5GTH or MEC_3FTH | – | ALT, DST.1, DST.2, DST.3, DST.4, DST.5, DST.6, DST.7, DST.8, DST.9, DST.10, DST.11, DST.12, DST.13, DST.14, DST.15, DST.16, DST.ALL, DST.NONE, FUNC.1, FUNC.2, FUNC.3, FUNC.4, FUNC.5, FUNC.6, FUNC.7, FUNC.8, FUNC.9, FUNC.10, FUNC.11, FUNC.12, FUNC.13, FUNC.14, FUNC.15, SHIFT, SRC.1, SRC.2, SRC.3, SRC.4, SRC.5, SRC.6, SRC.7, SRC.8, SRC.9, SRC.10, SRC.11, SRC.12, SRC.13, SRC.14, SRC.15, SRC.16, SRC.ALL, SRC.NONE | 642-5GTH92061 or 642-3FTH9Q | + 3mm leds for 3FTH | |||
| 1 | PEC12R | – | ENC | 652-PEC12R-4217F-S24 | ||||
| Connectors | ||||||||
| 1 | USB-B | THT | USB-B | 538-67068-8000 | ||||
| 1 | USB-A | THT | USB-A | 538-48204-0001 | ||||
| 1 | RJE0166201 | single RJ11 6p6c | MCAN | 523-RJE01-662-01 | ||||
| 2 | micro-match 2×5 | Female | J8/9A, J15A | 571-12150790 or 571-1-2178710-0(value line) | ||||
| 2 | micro-match 2×5 | IDC | J8/9B, J15B | 571-8-215570-0 | Paddle board | |||
| 1 | DM3AT-SF-PEJM5 | Socket | micro-SD | 571-8-215079-4 | with push-push | |||
| Others | ||||||||
| 2 | Screw terminal | – | – | 534-7790 | ||||
toDo
bandmaster.txt · Last modified: 2018/10/08 09:06 by antichambre
