If you're like me, you'd rather change the software mapping of the output (LED) pins than wire everything according to the original schematic - which may not even be possible due to differences in the CS. This HowTo will demonstrate one of the many ways to change the mapping according to your own wiring. This HowTo is only meant to change LEDs which are connected to individual pins. With LEDs connected as a matrix this will not work.
Difficulty level:
Required actions:
Affected files [1]:
setup_*.asm
Required software:
Digital Out Test SR# 1 Pin#0 0x00
Digital Out Test SR# 1 Pin#1 0x01
setup_*.asm
CS_MENU_DOUT_TABLE
which looks like this:CS_MENU_DOUT_TABLE ;; Register and bit SR# Pin# Description DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 0, 1, 0 ; SID1 LED (Note: Pin #0 is the D7 output of first SR) DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 1, 1, 1 ; SID2 LED DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 2, 1, 2 ; SID3 LED DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 3, 1, 3 ; SID4 LED DOUT_ENTRY CS_MENU_MODE, 0, 1, 4 ; Shift LED DOUT_ENTRY CS_MENU_MODE, 1, 1, 5 ; CC LED DOUT_ENTRY CS_MENU_MODE, 4, 1, 6 ; Edit LED DOUT_ENTRY CS_MENU_SELECTED_OSC_FLAGS, 0, 2, 0 ; OSC1 LED DOUT_ENTRY CS_MENU_SELECTED_OSC_FLAGS, 1, 2, 1 ; OSC2 LED DOUT_ENTRY CS_MENU_SELECTED_OSC_FLAGS, 2, 2, 2 ; OSC3 LED DOUT_ENTRY TMP1, 0, 2, 3 ; OSC Env LED DOUT_ENTRY TMP1, 1, 2, 4 ; OSC Misc LED DOUT_ENTRY TMP1, 2, 2, 5 ; OSC Assign LED DOUT_ENTRY TMP1, 4, 3, 0 ; OSC Triangle LED DOUT_ENTRY TMP1, 5, 3, 1 ; OSC Saw LED DOUT_ENTRY TMP1, 6, 3, 2 ; OSC Pulse LED DOUT_ENTRY TMP1, 7, 3, 3 ; OSC Noise LED DOUT_ENTRY TMP2, 0, 2, 6 ; OSC Sync LED DOUT_ENTRY TMP2, 1, 2, 7 ; OSC Ring LED DOUT_ENTRY TMP3, 0, 3, 4 ; Filter O1 LED DOUT_ENTRY TMP3, 1, 3, 5 ; Filter O2 LED DOUT_ENTRY TMP3, 2, 3, 6 ; Filter O3 LED DOUT_ENTRY TMP3, 3, 3, 7 ; Filter Ext LED DOUT_ENTRY TMP3, 4, 4, 0 ; Filter LP LED DOUT_ENTRY TMP3, 5, 4, 1 ; Filter BP LED DOUT_ENTRY TMP3, 6, 4, 2 ; Filter HP LED DOUT_ENTRY TMP3, 7, 4, 3 ; Filter 3O LED DOUT_ENTRY TMP2, 4, 4, 4 ; ENV1 LED DOUT_ENTRY TMP2, 5, 4, 5 ; ENV2 LED DOUT_ENTRY TMP2, 6, 4, 6 ; ENV Ctrl LED DOUT_ENTRY TMP2, 7, 4, 7 ; ENV Assign LED DOUT_ENTRY TMP4, 0, 5, 0 ; LFO1 LED DOUT_ENTRY TMP4, 1, 5, 1 ; LFO2 LED DOUT_ENTRY TMP4, 2, 5, 2 ; LFO3 LED DOUT_ENTRY TMP4, 3, 5, 3 ; LFO4 LED DOUT_ENTRY TMP4, 4, 5, 4 ; LFO5 LED DOUT_ENTRY TMP4, 5, 5, 5 ; LFO6 LED DOUT_ENTRY TMP5, 0, 5, 6 ; LFO Sine LED DOUT_ENTRY TMP5, 1, 5, 7 ; LFO Triangle LED DOUT_ENTRY TMP5, 2, 6, 0 ; LFO Saw LED DOUT_ENTRY TMP5, 3, 6, 1 ; LFO Pulse LED DOUT_ENTRY TMP5, 4, 6, 2 ; LFO Random LED ;; additional LED functions which could be added: ;; o Play LED (TMP5, 6) ;; o Mode Meter LED (TMP2, 2) ;; o Mode Matrix LED (TMP2, 3) ;; o SID L LED (TMP4, 6) ;; o SID R LED (TMP4, 7) ;; o LFO Positive LED (TMP5, 5) ;; don't remove this "end-of-table" entry! DOUT_ENTRY_EOT
(two semi-colons) to the beginning of that line. Like this:;; this LED will work DOUT_ENTRY CS_MENU_MODE, 0, 1, 4 ; Shift LED
;; this LED has been removed by commenting out ;; DOUT_ENTRY CS_MENU_MODE, 0, 1, 4 ; Shift LED
and the parentheseses and replace the name (“Play LED”) by DOUT_ENTRY
giving you this: ;; DOUT_ENTRY TMP5, 6
” + SR# + “,
” + Pin# giving you sth like this: ;; DOUT_ENTRY TMP5, 6, 4, 7
;; DOUT_ENTRY TMP5, 6, 4, 7 ;; Play LED - whee!
