dseq32_matrix
This page will contain the information about the combined lcd/button matrix forum topicuCApps
right now I'm using a modified version of the sm_simple C example
this code will be rewritten to make it more coherent
modifications to scan matrix example uCApps
in main.c:
//second shiftregister drives the leds
#define LEDOUT 1
void LM_SetRow(){
MIOS_DOUT_SRSet(LEDOUT,ledtest[sm_col]);
// This function is called by MIOS before the shift register are loaded
void SR_Service_Prepare(void) __wparam
// call the Scan Matrix Driver
SM_PrepareCol();
// call the Led Matrix Driver
LM_SetRow();
in sm_simple.asm:
... global _sm_button_column global _sm_button_row global _sm_button_value global _sm_col ;; import lables extern _SM_NotifyToggle ; ========================================================================== accessram udata ; (no access ram required, these variables can be located anywhere) _sm_button_column res 1 ; exported to C, therefore an "_" has been added _sm_button_row res 1 _sm_button_value res 1 _sm_col res 1 ... SM_PrepareCol ;; select next DOUT register ;; (current column + 1) & 0x07 SET_BSR sm_selected_column incf sm_selected_column, W, BANKED ; (* see note below) andlw 0x07 ;_sm_col is used by LM_SetRow() movwf _sm_col call MIOS_HLP_GetBitANDMask ; (inverted 1 of 8 code) ...
and finally in sm_simple.h:
... extern unsigned char sm_button_value; extern unsigned char sm_col; ...
back to DSEQ32
dseq32_matrix.1152139425.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
