dseq32_matrix
This page will contain the information about the combined lcd/button matrix forum topicuCApps
right now I'm using a modified version of the sm_simple C example
this code will be rewritten to make it more coherent
modifications to scan matrix example uCApps
Hardware
DOUT wiring
DIN wiring
*note: schematics not finished!
Software
in main.c:
//second shiftregister drives the leds
#define LEDOUT 1
void LM_SetRow(){
	MIOS_DOUT_SRSet(LEDOUT,ledtest[sm_col]);
// This function is called by MIOS before the shift register are loaded
void SR_Service_Prepare(void) __wparam
  // call the Scan Matrix Driver
  SM_PrepareCol();
  // call the Led Matrix Driver
  LM_SetRow();
in sm_simple.asm:
	global	_sm_button_column
	global	_sm_button_row
	global	_sm_button_value
	global  _sm_col
	;; import lables
	extern	_SM_NotifyToggle
accessram		udata		; (no access ram required, these variables can be located anywhere)
_sm_button_column	res	1	; exported to C, therefore an "_" has been added
_sm_button_row		res	1
_sm_button_value	res	1
_sm_col				res 1
SM_PrepareCol
	;; select next DOUT register
	;; (current column + 1) & 0x07
	SET_BSR	sm_selected_column
	incf	sm_selected_column, W, BANKED	; (* see note below)
	andlw	0x07
	;_sm_col is used by LM_SetRow()
	movwf	_sm_col
	call	MIOS_HLP_GetBitANDMask	; (inverted 1 of 8 code)
and finally in sm_simple.h:
extern unsigned char sm_button_value;
extern unsigned char sm_col;
Appendum
To avoid flickering leds when pushing a button the MIOS button debouncing should be turned off!!
Due to the setup of the SRIO driver the debounce algoritm also delays the DOUT chain when a DIN event is being debounced. So when a button is pushed the led update frequency is reduced, the higher the debounce value, the lower the update frequency.
According to this post TK will fix this in a future MIOS release:
This is something what I'm planning to solve in one of the next MIOS versions - currently the same SR scanning routine is used for DIN and DOUT registers, which means, >when the DINs are temporary disabled due to the cheap debouncing method, the DOUT registers won't be updated.
The solution is to add a second scan routine which only services the DOUTs so long the debouncing delay is active.
In the meantime THIS ISSUE IS SOLVED WITH MIOS1.9c!!!
Workaround
To turn the debouncing off, set
#define DIN_DEBOUNCE_VALUE    0
back to DSEQ32
dseq32_matrix.txt · Last modified: 2006/10/15 09:35 by 127.0.0.1
