electronics_diy_common_tools
DIY Common Tools for Electronics
You will find Here a List of Common Tools Used For Electronics DIY.
You don't absolutely need to have all of these things, but it sure helps!
Using a tool for purposes other than those for which it was designed can be just a little more difficult, or downright dangerous. Please be safe :)
General / Safety
General
- Workbench - Protect your house, have a proper work area
 - Storage Unit - Put your tools and components somewhere safe
 - Small Plastic Cups - Somewhere to put things temporarily. Don't leave your kit lying around.
Safety
- Safety Glasses - Protect your sense of sight
 - Face mask - Protect your lungs
 - Fire Extinguisher - Don't let your soldering iron start a fire you can't put out
 - Fire Blanket - As above
 - Soldering Smoke Absorber/Ventilator - MMmmm, Lead smoke. Mmmmm, Cancer. Mmmm, Insanity. Mmm…. I think not.
Electrical Instruments
- Multimeter - For testing circuitry Voltages, Resistors and Transistors
 - Oscilloscope - For testing signals. Dual trace is better , allow signals comparison
 - Power Supply - Regulated lab power supply . Help in getting the right Voltages inputs
Video Tutorials
Soldering
- Soldering Iron or Station with Stand- Temperature controlled
 - Solder - Good quality solder for good quality joints, 63/37 Eutectic
 - Desoldering Pump - - For removing soldered chips
- Soldering Iron Tip Cleaner - Take care of your tools
 - Tinning Block - for taking care of soldering iron tips
 - PCB Holders - Make soldering easier and cleaner
Trimming and Fastening
- Cutters - For trimming componenet leads
 - Screwdriver Set - Various sizes
 - IC Puller / Placer
 - Wire Strippers - For stripping insulation from cabling
 - Pliers Set - Various Sizes and types
 - Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach
 - IDC Crimping Tool - Because doing it with pliers sucks
 - Electrical Tape
Misc
- Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach
 - Compressed Air Can - For cleaning stuff by blasting off dust
electronics_diy_common_tools.1468940865.txt.gz · Last modified: 2016/07/19 15:07 by psykhaze
