english_version
! Click to Enlarge !
Features :
  • Mixing For Traktor V.2 / V.3….only 2 Decks !
  • Volume, Low/Mid/High-EQ-Pots + Kill-Buttons, Gainpots
  • Crossfader
  • Deckeffect-section - Effectselection via Pot
  • Loopsection - 1,4,8,16-step buttons, prev-next Buttons
  • Reverse Play
  • Track Begin Button - when a Track is running out and you want to switch the other track from -cue to -startposition
  • Transpose Fader
  • Pitchbend - with Jogwheel (Encoder) and Buttons
  • Windfunction - with Encoder and Buttons
  • Mastereffectsection - also Effect-selection via Pot
  • Mastervolume , Headphone-Volume and Headphone-Mix - via Pot
  • Midi In/Out and Serial Interface
Update
  • LED-Arrays on both Volume Faders
  • LEDs on Effektselection-Pot, you can see now via LED which Effect is selected
  • Pot-Middle-Position on Bass/Mid/High/Gain now signalized via LED
  • same function for Pitch-shift,Crossfader & Transpose-faders
  • one LED putted on Headphonemix-Pot, for “0”-Position
Download
Solderplans for the Modules (PDF-Format)
  • AIN - Pots / Faders
  • DIN - Buttons / Encoders
  • DOUT - LEDs
  • Pin-Tables - Table for AIN,DIN & DOUT (Sodering & Programming)
Firmware
Demovideo
Upcomig updates
  • Scratching
Status : under construction :)
english_version.txt · Last modified: 2006/12/12 18:44 (external edit)
