etching_pcb
Etching PCB DIY
Before sending some PCB to get pro made (really the best time proof solution) it is useful to debug it by etching it yourself
Toner Transfer
A Simple and costless method Flow to make proto PCB based upon Laser Printed Negative and Laminator/Ironer.
The laminator need a hack to increase heating temperature , but it's a more precise way ta make the transfer than ironer.
Simple side Transfer + Etching
Double side Transfer + Etching
Laminator Transfer
Direct Laser Transfer
Isolation Milling
A method that uses CNC to engrave around paths to isolate them from rest of PCB board
etching_pcb.1469289218.txt.gz · Last modified: 2016/07/23 15:53 by psykhaze
