These projects are primarily the work of TK, the founder of the MIDIbox community.
midibox_64 Pot-based MIDI controller
midibox_64e Encoder and pot-based MIDI controller
midibox_lc Logic Control HUI emulation
midibox_mm MotorMix HUI emulation
stribe Softpot-based MIDI controller
midibox_seqv2 MIDI step sequencer
midibox_seqv3 MIDI step sequencer
midibox_808 Roland 808 clone
midibox_fm OPL3 chip based synthesizer
midibox_sid SID chip based synthesizer
midibox_sidv2 SID chip based synthesizer
analog_toolbox Analog CV controller
clockbox MIDI clock sync source
magic_midi_delay MIDI delay effect
midibox_cv Analog CV controller
midimon MIDI Monitor
midi_router Multi-port MIDI router
These projects are the works of MIDIbox community members, which are completed and documented. See also the MIDIbox User Projects section of the forum.
midi_mapper MIDI Mapper
Not documented on the wiki, no longer 'officially supported' if there was such a thing ;)
please build these only with a good reason :
