====== MIDI Router ====== ====== Intro ====== [[http://www.ucapps.de/midi_router.html|Midi Router]] is a project which allows you to route MIDI messages to/from multiple MIDI ports on the MIDIbox Please, if you decide to build a midirouter, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midirouter version etc...it helps newbies a lot. Also, if you are reading this and have built a midirouter that you created, it'd be cool if you take a photo too and insert a link to it from here. ====== Features ====== Up to 8 MIDI I/Os Customisable routing through simple C code ====== Skills / Equipment Required ====== [[:home:skills:tools|Tools]] [[:home:skills:Soldering]] ====== Hardware ====== ===== What modules do I need? ===== Adjust List as required: [[:home:mbhp:module:core | Core Module]] [[:home:mbhp:module:lcd | LCD Module]] [[:home:mbhp:module:bankstick | Bankstick Module]] [[:home:mbhp:module:din | DIN Module]] [[:home:mbhp:module:dout | DOUT Module]] [[:home:mbhp:module:iic_midi | IIC Midi Module]] ===== Parts List ===== List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links [[:home:mbhp:parts | Where to buy Parts]] ===== Connections ===== Connection diagrams - links if needed (create in you projects namespace ===== Enclosure / Case ===== Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs ==== Enclosure References ==== [[:home:skills:constructing_enclosures | Constructing Enclosures]] ====== Software ====== ===== Setting Up ===== We recommend you read [[:home:software]] before you continue. ===== Download ===== Links ===== Setup Instructions ===== Up to you ====== Extra ====== [[:home:project:<thisproject>:manual | Usage Manual]] Anything else
