====== M16 Interface ====== **Add 16 MIDI I/O to your Core, SPI Slave Interface with up to 16 UARTs(MIDI I/O), based on low-cost FPGA...** \\ \\ ---- \\ <wrap round important 7%> toDo </wrap> \\ Some connection examples\\\\ Spi slave kissbox emulation, share protocol and added commands\\ Features\\ * The FPGA internal clock works @88.67MHz. * Fast 4 wires SPI in slave mode to control the board, 10Mb/s. * Uses the default MIOS32_SPI_MIDI protocol, MIOS32 is ready-to-use with it. * 16 UARTs on board, it's 16 MIDI ports. * Each MIDI output has its own FIFO buffer of 1024 bytes, to queue the incoming MIDI from the SPI. * Each MIDI output has its independent "Running Status", with Disable/Enable Command from SPI. * There's a 64 word(32bits) FIFO for out-coming messages from the board. * 3 independents groups of 16 GPIOs, configurable and settable by SPI Command. In MIOS32\\ datasheet\\
