mb_sync24
MB Sync24 converter
Sync24 is (was) used by Roland, to syncronise machines before the midi became popular.
Basicaly, it's just a “pulse clock sync” at 24ppqn (24 pules per quarter note)
This converter help to sync your Roland Tb-303 Tr-606 Tr-808 to sync with midi, or to sync your apeggio (sh-101 / juno60 etc..)
Such a device allready exist and is distributed by :
but it's often pretty expensive. (From 50 to 100euro)
Now, you can build your own for much less.
It's working both ways :
  1. Midi clock to Sync24 (the most often this is what you want)
  2. Sync24 to Midi clock
The hardware
It is made of :
  1. A core module
  2. A dout module (if you want to convert Midi → Sync24 )
  3. A din module + a lil board (if you want to convert Sync24 → Midi )
(i will describe this part later, because i must improve it)
You dont need a screen, so it can works with batteries for quite a long time.
Sync24 Connector
Sync24 Connectors Are Not MIDI Cables
Dont use midi cables as sync24 cables, because the wiring is different, and most often, the pins 1 and 5 used by sync 24 are left unwired in midi cables.
The program
Is still beta, but working fine. It's tested in both directions with :
  1. TR626 (midi),
  2. Yamaha RM1X (midi),
  3. TR909 (midi AND sync24)
  4. TR808 (sync24)
  5. TR606 (sync24)
  6. TB303 (sync24)
  7. Nintendo Gameboy running LSDJ ('kind of' sync24)
  8. MidiOX :)
Get it here : http://sidabitball.free.fr/cli/sync_boy/MB-sync0.7.zip (Link was temporarly offline!!)
mb_sync24.txt · Last modified: 2011/09/09 02:54 by gslug
