midibox_ay_patch_menu
MIDIBox AY 3 8912 - PATCH MENU
Access the PATCH MENU via F1 (C64 Keyboard)
PATCH MENU Options:
  • Store A Patch (Patch 0) to Eeprom (PIC 18F Eeprom, no Bankstick1 needed)
  • Store A Patch (Patch 1 to 127) to Bankstick1 (BS)
  • Format Bankstick1
The Patch Menu - Overview:
LCD ROWFunc.DataMemo
1NAME: PATCHNAME Edit the Patchname here
2NR : 0 to 127 Select the Patch Number here (Patch 0 = PIC internal Patch / 1 to 127 = Bankstick Patches)
3DO : L W F Do Load Patch, Write Patch, Format Bankstick1
4status (info) (W: OK, L: OK, F: BS PATCH 1-127)
Patch Menu - Editing:
LCD ROW EDIT KEYS
1NAME Use A-Z, 0-9, SPACE = “_”, after Patchname Editing the user can delete the Patchname via INST DEL key
2Nr. Use crsr ← → (+ / -)
3Do Use L W F
4status (info)
Annotation:
  • Bankstick (BS) = Bankstick1 by default
  • Bankstick Formatting: Patch 1 to 127 will be written with the current Patch data (!). For instance: set the MIDI Channel Tone A to 8. Now every Bankstick Patch (1 -127) will have the MIDI Channel 8 (@Tone A) after Bankstick formatting (in this way it is easy to predefine a Patch Setup for all 127 Bankstick Patches).
  • A “ ! ” before the [Patchname] (@LCD ROW1) indicates, that the Patch is NOT loaded yet.
  • The Fx Data will be stored
  • Patchname Cursor Pos. +1 = [CRSR →] or [+] or [>]
  • Patchname Cursor Pos. -1 = [CRSR ←|(+SHIFT)] or [-] or [<]
  • [INS DEL] or [CLR HOME] delete the patchname after patchname editing (this do not delete the patch data!).
midibox_ay_patch_menu.txt · Last modified: 2010/03/29 10:06 by lemonhorse
