midibox_ay_patch_menu
MIDIBox AY 3 8912 - PATCH MENU
Access the PATCH MENU via F1
The Patch Menu:
| LCD ROW | Func. | Data | Memo |
| 1 | NAME: | PATCH NAME | Edit the Patch Name here |
| 2 | NR : | 0 to 127 | Select the Patch here (Patch 0 = PIC internal Patch / 1 to 127 = Bankstick Patches) |
| 3 | DO : | L W F | Do Load Patch, Write Patch, Format Bankstick1 |
| 4 | status | (info) | (W: OK, L: OK, F: BS PATCH 1-127) |
Annotation:
| LCD ROW | EDIT | KEYS |
| 1 | NAME | Use A-Z, 0-9, SPACE = “_”, after Patch Name Editing the user can delete the Patch Name via INST DEL key |
| 2 | Nr. | Use crsr ← → (+ / -) |
| 3 | Do | Use L W F |
- Bankstick = Bankstick1 by default
 - A “ ! ” before the [Patch Name] (@LCD ROW1) indicates, that the Patch is NOT loaded yet.
 - The Fx Data is included (will be stored)
 - Patchname Cursor Pos. +1 = [CRSR →] or [+] or [>]
 - Patchname Cursor Pos. -1 = [CRSR ←|(+SHIFT)] or [-] or [<]
 - [INS DEL] or [CLR HOME] delete the patch name after patch name editing (this do not delete the patch data).
midibox_ay_patch_menu.1258883800.txt.gz · Last modified: 2009/11/22 09:56 by lemonhorse
