mios_pin_list
MIOS Pin List
This list gives you an oversight over the pin usage of MIOS.
Name Class Core Port:Pin PIC Pin # Direction Additional Information
RA0 A J5:A0 2 Input analog pin
RA1 A J5:A1 3 Input analog pin
RA2 A J5:A2 4 Input analog pin
RA3 A J5:A3 5 Input analog pin
RA5 A J5:A4 7 Input analog pin
RE0 A J5:A5 8 Input analog pin
RE1 A J5:A6 9 Input analog pin
RE2 A J5:A7 10 Input analog pin
RA4 K J4:SD 6 Input / Output IIC data pin SD, external 1k pull-up, can be used by an application for other purposes so long MIOS_IIC_* won't be called
RC0 B J6:RC / J7:RC 15 Output used to address the AIN multiplexers or the MF module. In both cases driven by an interrupt service routine.
RC1 B J6:SC / J7:SC 16 Output used to address the AIN multiplexers or the MF module. In both cases driven by an interrupt service routine.
RC2 D J7:SO 18 Output used as serial output to the MF module, driven by an interrupt service routine.
RC3 C J6:SI / J10:PWM 17 Output used to address the AIN multiplexers, driven by an interrupt service routine / SID PWM. This pin is stuffed with an external 10k pull-up which could be useful for an application which uses this pin as input
RD0 E J8:SO 19 Output serial output to the DOUT chain, driven by an interrupt service routine if MIOS_SRIO active
RD1 E J9:SI 20 Input serial input to the DIN chain, used by an interrupt service routine if MIOS_SRIO active
RD2 F J8:RC / J9:RC 21 Output serial latch output, used by an interrupt service routine if MIOS_SRIO active
RD3 F J8:SC / J9:SC / J10:SC 22 Output serial clock output, used by an interrupt service routine if MIOS_SRIO active / SID SC
RC4 G J10:RC 23 Output SID RC / free for applications without restrictions if second CLCD not used
RC5 G J10:SO 24 Output SID SO / free for applications without restrictions
RD4 E J14 27 Output touch sensor strobe signal, used by an interrupt service routine if MIOS_SRIO active and TS_Sensitivity > 0
RD5 H J4:SC / J10:MD / J15:RS 28 Output clock output to IIC / SID MD / address signal to LCD
RD6 H J10:MU / J15:RW 29 Output SID MU / RW signal to LCD
RD7 I J15:E 30 Output enable signal to LCD (exclusive!)
RB0 J J15:D0 33 Input / Output LCD data line #0
RB1 J J15:D1 34 Input / Output LCD data line #1
RB2 J J15:D2 35 Input / Output LCD data line #2 / CAN Tx
RB3 J J15:D3 36 Input / Output LCD data line #3 / CAN Rx
RB4 J J15:D4 37 Input / Output LCD data line #4
RB5 J J15:D5 38 Input / Output LCD data line #5
RB6 J J15:D6 39 Input / Output LCD data line #6
RB7 J J15:D7 40 Input / Output LCD data line #7
The pins are divided into following classes:
  • Class A: analog inputs, which can be optionally used as digital inputs or outputs like demonstrated in the j5_dout and j5_din example if the MIOS_AIN and MIOS_MF driver are not used
  • Class B: digital pin which is free for applications if neither the MIOS_AIN multiplex driver, nor the MIOS_MF driver is active Also free if MIOS_AIN doesn't run in mux mode
  • Class C: digital pin which is free for applications if the MIOS_AIN multiplex driver isn't active
  • Class D: digital pin which is free for applications if the MIOS_MF driver isn't active
  • Class E: digital pin which is free for an application if the MIOS_SRIO driver isn't active. Can also be shared with other devices if the application accesses the pin from an interrupt service routine or if it disables all interrupts for a short time (< 300 uS!). Touchsensor Pin.
  • Class F: digital pin which is free for an application if the MIOS_SRIO driver isn't active.
  • Class G: free pin which can be used by the application without any restrictions
  • Class H: digital pin which can be shared with other modules (LCD/IIC/…) Shouldn't be used from an interrupt service routine
  • Class I: digital pin, exclusive for LCD
  • Class J: digital IO pin, can be shared with the LCD data lines as IO pins so long J15:E is low (means: MIOS doesn't execute a MIOS_LCD function) Shouldn't be used from an interrupt service routine
  • Class K: see description
See also the schematic of the MBHP_CORE module as reference, or this PCB layout:
This table is based on the original from mios_pin_list.txt
mios_pin_list.txt · Last modified: 2011/11/29 17:01 by smashtv
