no_nc
                Normally Open/Normally Closed contact. Generally pertains to a set of contacts on a switch or relay and the position that they are normally found in. NO is normally open and usually means the circuit is open. NC is normally closed and usually means the circuit is engaged and capable. See switch.
no_nc.txt · Last modified: 2006/10/15 09:35 by 127.0.0.1
