====== Sensors ====== {{ :neonking:neuralelectrode.jpg?direct&300|}} ===== Introduction ===== Here some informations about various sensor-types and how to connect them to a midibox. Keep in mind that **most of sensors are analog , so they require an AINSER Module to be plugged as inputs to the Core Board**. Sensor-Wiki maintains a free list of possible sensors you could experiment with . For example the picture on the right is a EEG Active Electrode from the OpenEEG Project. A mind-controlled midibox ? who said that ? * http://www.sensorwiki.org/doku.php/sensors/introduction * http://openeeg.sourceforge.net/doc/ If you're interested in working with sensors, you might also want to check out the [[ACSensorizer]]-Midibox project. ===== Forum Topics ===== * [[http://midibox.org/forums/topic/6057-connecting-non-10k-resistance-based-sensors/#comment-40071|How to connect Non-10k Resistance-based Sensors]] * [[http://midibox.org/forums/topic/12260-experimental-controllers-sensors-ribbons-et-cetera/#comment-110394|Experimental controllers-sensors-ribbons]] * [[http://midibox.org/forums/topic/4906-distance-sensor-like-d-beam-controler/#comment-31901|About Distance Sensors]] * [[http://midibox.org/forums/topic/19097-adafruit-touch-sensors/#comment-166581|AdaFruit touch Sensor]] * Touch Sensors (as Buttons): http://www.midibox.org/forum/index.php?topic=9220.0 * How to connect Flex-Sensors: http://www.midibox.org/forum/index.php?topic=5388.0 * Accelerometers, Tilt-Sensors: http://www.midibox.org/forum/index.php?topic=1985.0
