seq_buttons
Summary
This page is for describing the functions found in the file seq_buttons.inc in the MBSEQ v2.4a application.
seq_buttons.inc contains the handler functions for button presses. USER_DIN_NotifyToggle calls SEQ_Button_Handler which first checks to see if the button press came from one of the two shift registers which are assigned in main.asm to be the 16 general purpose buttons.
Functions
SEQ_BUTTON_Handler
SEQ_BUTTON_Handler_ChkGP1
SEQ_BUTTON_Handler_ChkGP2
CS_MENU_BUTTON_Handler_NoGP
SEQ_BUTTON_Handler_Loop
SEQ_BUTTON_Handler_End
SEQ_BUTTON_GP
SEQ_BUTTON_GP1
SEQ_BUTTON_GP2
SEQ_BUTTON_GP3
SEQ_BUTTON_GP4
SEQ_BUTTON_GP5
SEQ_BUTTON_GP6
SEQ_BUTTON_GP7
SEQ_BUTTON_GP8
SEQ_BUTTON_GP9
SEQ_BUTTON_GP10
SEQ_BUTTON_GP11
SEQ_BUTTON_GP12
SEQ_BUTTON_GP13
SEQ_BUTTON_GP14
SEQ_BUTTON_GP15
SEQ_BUTTON_GP16
SEQ_BUTTON_GP_Cont
SEQ_BUTTON_Select
SEQ_BUTTON_Exit
SEQ_BUTTON_Left
SEQ_BUTTON_LeftRemote
SEQ_BUTTON_Right
SEQ_BUTTON_RightRemote
SEQ_BUTTON_StartStop
BUTTON_Control4SetStart
SEQ_BUTTON_StartStop_Stop
SEQ_BUTTON_Pause
SEQ_BUTTON_Rew
SEQ_BUTTON_Fwd
SEQ_BUTTON_Play
SEQ_BUTTON_Stop
SEQ_BUTTON_Continue
SEQ_BUTTON_Edit
SEQ_BUTTON_Mute
SEQ_BUTTON_Pattern
SEQ_BUTTON_Song
SEQ_BUTTON_Song_Toggle
SEQ_BUTTON_Song_Toggle_1
SEQ_BUTTON_Song_Toggle_0
SEQ_BUTTON_Song_Toggle_Cont
SEQ_BUTTON_Song_NoToggle
SEQ_BUTTON_Menu
SEQ_BUTTON_Metronome
SEQ_BUTTON_Scrub
SEQ_BUTTON_Solo
SEQ_BUTTON_All
SEQ_BUTTON_Fast
SEQ_BUTTON_Fast_Loop
SEQ_BUTTON_LayerA
SEQ_BUTTON_LayerB
SEQ_BUTTON_LayerC
SEQ_BUTTON_Layerx
SEQ_BUTTON_Layerx_MPS
SEQ_BUTTON_Layerx_Edit
SEQ_BUTTON_Layer_Depr
SEQ_BUTTON_Track1
SEQ_BUTTON_Track2
SEQ_BUTTON_Track3
SEQ_BUTTON_Track4
SEQ_BUTTON_Trackx_Cont
SEQ_BUTTON_Trackx_MPS
SEQ_BUTTON_Trackx_Edit
SEQ_BUTTON_Trackx_Toggle
SEQ_BUTTON_Trackx_Radio
SEQ_BUTTON_Trackx_End
SEQ_BUTTON_Trackx_Hlp_Sav
SEQ_BUTTON_F1
SEQ_BUTTON_F2
SEQ_BUTTON_F3
SEQ_BUTTON_F4
Function Descriptions
SEQ_BUTTON_Handler_ChkGP1 first moves MIOS_PARAMETER1 into W, AND's W with 0xf8 and then xorlw's against “(DEFAULT_GP_DIN_SR0 - 1) « 3” which, presumably results in zero if the registers match. Perhaps the AND statement converts the button number in MIOS_PARAMETER1 into a value representing which SR it belongs to.
SEQ_BUTTON_Handler searches through mios_tables.inc for a DIN pin that matches MIOS_PARAMETER1 and then calls the appr. function
From the comments:
GP button number is stored in MIOS_PARAMETER1, button value in MIOS_PARAMETER2 (1 for released, 0 for pressed)
If the button press did come from one of the GP's then the program branches to SEQ_GP_Button in seq_gp.inc, not to be confused with SEQ_Button_GP in seq_button.inc.
seq_buttons.txt · Last modified: 2006/10/15 09:35 (external edit)
