This board holds the SEQ's illuminated buttons, which are driven from a shift register matrix. The ENC-PLATE board stacks on top.
A shift register chain of 3 DIN 74HC165 and 2 DOUT 74HC595 chips are used. Two of the DINs scan the encoders and one scans the button columns. The DOUT parts are connected into a matrix. Note that both the high and low sides have driver transistors (PNP and NPN, respectively). This means that the anode side of the matrix will operate with inverted behaviour (pin high = LED off).
There are special instructions for connecting the parts which are covered below.
Resistors | |||||||||
1 | wire link | THT | R17 | ||||||
18 | 47R 5% | THT | RJ1-9 | see instructions | |||||
8 | 100-220R 5% | THT or 1206 | SJ1-8 | see instructions | |||||
16 | 1k 5% | THT | R1-16 | ||||||
Resistor networks | |||||||||
3 | 9*10k | SIP10 | RN1-3 | bussed network, not 5 pairs of resistors | |||||
Capacitors | |||||||||
5 | 100n | 1206 | C1-5 | ||||||
0 | do not fit | C6 | |||||||
Diodes | |||||||||
24 | 1N4148 | THT | |||||||
LEDs | |||||||||
16 | RGB flat | superflux | ELV: 68-10 94 64 | see instructions | |||||
8 | various | 3mm | insert into switches | ||||||
Transistors | |||||||||
8 | BC808 | PNP SO-23 | |||||||
8 | BC818 | NPN SO-23 | |||||||
ICs | |||||||||
3 | 74HC165 | SOIC16 | IC1, IC3, IC5 | 595-SN74HC165DR | |||||
2 | 74HC595 | SOIC16 | IC2, IC4 | ||||||
Switches | |||||||||
16 | Matias | QuietClick | SW1-16 | see notes | |||||
8 | MEC/APEM | 3FTH9 | SW17-24 | 642-3FTH9 | TASTER 3FTH9 | 705276 - 62 | |||
Headers | |||||||||
1 (3) | 1*3 | male | |||||||
3 | 1*10 | male | |||||||
2 | 2*5 | male | |||||||
Hardware | |||||||||
16 | switchcaps | ALPS-DSA clear | |||||||
8 | switchcaps | 19mm | 642-1S11-19.0 | 1S11-19.0 |
note that two sets are required per SEQv4+ build!
v1.0: first release.
Take your time as some of these parts require some patience.
High-brightness LEDs are often expensive or don't have viable mounting options. To get around this, we will use flat-top superflux/piranha RGB LEDs and bend the legs over to make a pseudo SMT part :). There are at least two different LED pinouts, so make sure you know how yours function.
Important is:
The LEDs are available in RGB, but the official MIDIbox SEQ software only supports two of these colours. (if wanted, you could attach 0.1“ headers to the PCB and drive the LEDs with custom hardware.) So we need to select what LEDs are in the matrix using the resistor jumpers (RJ). Find RJ1-8 spanning across the middle of the board. Pins A(1-8) and B(1-8) represent the 8 anode busses and pins 1, 2 and 3 represent the pins of the LEDs in the row.
SJs are similar. As the current is quite high to drive the RGB LEDs, it's wise to use a 100-220R resistor to provide suitable current to the MEC LEDs. The position should match 1, 2 or 3 (two arbitrary positions) according to how the RJ of the same column is connected. Note that the forward voltage of the MEC switch LED should be the same as the position chosen on the RGB LED. For instance, if RJ was set to “3” (blue LED) and a red LED was used in a MEC switch, then the current path may illuminate the red one over the blue.
Continue on with the header pins. J5 should be connected to the Beat LED PCB; this needs some more thought. Header J14 can be used as a +5V supply. 1*10 Headers J1-3 can be installed, but best in conjunction with the ENC-PLATE PCB to ensure correct alignment.
Here is a good point to test out the BLM function. Some MB_NG app? With the Plate PCB to test out the DIN side?
Notice that the switches have not yet been soldered in. It should be alright to put in the MEC switches, as long as the LEDs have been inserted first! Like the Jog module, the switches must be installed with the LEDs polarised correctly. The clearance with the Plate PCB is tight, so keep them straight.
Very important: the Matias switches must go in through the completed Plate PCB! If they are put in before the Plate PCB, the Plate PCB won't fit and there will be no way to mount the encoders!
Once the Matias switches are in, this should basically be the final step of le MEC.
