ssm2044_pcb [2011/08/31 13:33] pierrehernandez |
ssm2044_pcb [2016/06/22 00:25] psykhaze |
Line 1: | Line 1: | ||
- | ==== Dual SSM 2044 VCF ==== | + | ====== Dual SSM 2044 VCF ====== |
[[http://midibox.org/forums/index.php?/topic/13999-mbhp-eth-mbhp-sdcard-ssm2044-ssm2164-pcb-bulk-order|SSM2044 PCB Bulk Order]] | [[http://midibox.org/forums/index.php?/topic/13999-mbhp-eth-mbhp-sdcard-ssm2044-ssm2164-pcb-bulk-order|SSM2044 PCB Bulk Order]] | ||
Line 108: | Line 108: | ||
After the resonance is calibrated, you can now crank it up all the way to tune the cutoff frequency more exactly. | After the resonance is calibrated, you can now crank it up all the way to tune the cutoff frequency more exactly. | ||
- | [[http://cvresumewritingservices.org/|resume writing services]] | ||
