tk_gm5_bulkorder
GM5 is an Atmel AVR based USB chip with preburned USB-MIDI firmware (out-of-the-box solution)
This product has been developed by http://www.ploytec.de
Schematics and Eagle file of the PCB: http://www.ucapps.de/mbhp_usb_gm5.html
The chip works under Windows/MacOS/Linux with the common USB-MIDI-Driver, but there is also a custom driver for Windows available to overcome the Microsoft driver flaws (a drawback of the old MBHP_USB module)
Per chip you will get 5 physical MIDI IOs. The dedicated Windows driver makes it multi-client capable. Under MacOS the interface is multi-client capable by default.
Package: TQFP32 (SMD, but can be soldered with a good soldering iron similar)
History:
Bulk OrderGM5 QuantityPCB Quantity
1st500400
2nd25095
3rd250105
4th250100
5th2500
6th250100
—IN STOCK—00
No additional bulk order planned in future!
Meanwhile Ploytec sells GM5 chips in lower quantities (10 pieces): https://www.usb-audio.com/gm5/
Check the Fleamarket if somebody started a new order: http://midibox.org/forums/forum/36-fleamarket/
tk_gm5_bulkorder.txt · Last modified: 2015/09/06 14:42 by admin
