TriggerMatrix V4
CODE, FIRMWARE
Install MIOS Studio, connect TM4 via USB, and Start the STUDIO
1. Upload MIOS BOOTLOADER
2. (only needet for Virgin Machines) type following commands into the MIOS-TERMINAL:
3. (for Version Updates) Unzip the TM4-Firmware, and Upload the TM4.hex
4. Unconnect USB & Connect the USB again — finished.
BUILD
BOM, Components, PCBs
Full Sized SD-CARD, which is not Hi-Capacity, eg take 4 or 8GB Cards!
2x Wood: 15 x 400 x 39mm, or > 16 x 400 x 39mm (39mm is minimal, i took 40mm…)
1x Wood: 15 x 335 x 39mm, or > 16 x 333 x 39mm (39mm is minimal, i took 40mm…)
3mm Alu Plates for Ground and Backpanel (you cut and drill it by your own)
3mm Alu Frontpanel, CNC-machined (See DXF-File for more info)
Pictured Doku
Features
Short spoken:
16xdrumtriggers > Trigger-Routing-Matrix > Drum-Syntesizers
5x Poly Melody-lines > Trigger-Routing-Matrix > Melody-Syntesizers (track 1-5)
7x Mono Melody-lines > Trigger-Routing-Matrix > Melody-Syntesizers/Pitachable Drums (track 6-12)
Rules:
Drum-Trigger are Velocity Master > we dont care about the velocity of the Melodys
There are Songs (ProgramChange), each Song has 8 different Trigger-Routings Presets> these are the Song-Parts
Each Song has 4 StepSequencer-Variants (Rythms)
Each Song can Remote up to 6 Melody Scenes (LoopA-compatible!)
256 Songs saved on SD-Card, and Load-able while playing
The Tempo has to be changed by Hand or Midi, it is not saved with the song
System-Settings, like Ports or MidiChannels are Hardcodet, but there will be a sys-menue in near future
Triggermatrix midi-outs are connected to all synths, so it manage the program-change also
16x Trigger-OUTs with fixed Notes, on one midichannel - to connect Drum-Synths, Drum-Samplers
5x Polyphonic Melody-Retrigger-OUTs on 5 MidiChannels - to connect MelodySynths to it
7x Monophonic Melody-Retrigger-OUTs on 7 MidiChannels - to connect Monophonic Synths like pitchable Drums or Bass-Synths
- i think 1-5 is poly the rest is mono!
All 16 Trigger & ReTrigger-OUTs share the same Routing and Channelstrip UI (Mute, Solo, Roll…)
Trigger, Poly, Mono-OUTs can be controlled seperatly by > Random-Kill & Velocity-OFFSet
5×16 Melody-Input-Matrix - Route & Mix Melody Inputs to the 16 Melody-Retrigger-Outs (saved in Song)
16x Melody-Input-Matrix-Hold-Buttons - hold the last Note, save it in the Patch - usefull when pitch drums.
the Matrix has also a Trigger-Sequencer built in, the Melodys have to come from anywhere else, but @ the end, they have to be plugged into the matrix…
Trigger-sequencer, a few facts:
is a Drum-Step-Sequencer
256 Steps in total
32 th fixed rate
3,4,5,7,11,13/4 tact
minimal LoopSection is 16steps = 1 Page, there are 16 pages to chain
intro LoopSection, from step 0 until to the “minimal LoopSection”- is played once, then it loops the normal LoopSection
The sequencer is made to give a static NoteStream, the Song-Structure is done LIVE by the TriggerMatrix-ROUTER
Full Velocity control, visible with 3 different colours, Velocity Set via FADER
Free programmable Swing to each Step, with 2 different swing Length-sets, which are controlled live with encoder
copy, paste, erase of pages
copy, paste, erase of rows
fixed forward play direction
Getting Involved ?
