wcore_line-transmit
Line Transmit
A slightly more compact version of the MBHP Line Driver Transmitter.
Schematic
The two obvious differences are the J3 jumper (disconnects +5V from being sent) and the addition of a 100mil header. This way a DB-25 (or something else?) with ribbon cable mounting could be positioned off-board and wired to the line driver with an IDC.
BOM v1.0
Please find the current BOM on http://midiphy.com. The table below is depreciated and will not be updated.
| Resistors | |||||||||
| 0 (2) | 100R 5% | THT | not really needed | ||||||
| Capacitors | |||||||||
| 2 | 100nF | THT 2.5mm | C1, C2 | ||||||
| ICs | |||||||||
| 2 | MC3487 | DIP16 | IC1, IC2 | ||||||
| IC sockets | |||||||||
| 2 | DIP16 | ||||||||
| Headers | |||||||||
| 2 | 1*2 | male | |||||||
| 1 (0) | 1*3 | male | |||||||
| 2 | 2*5 | male | |||||||
| 0 (1) | 2*13 | male | |||||||
| Sockets | |||||||||
| 1 (0) | DB-25 | female | |||||||
| Hardware | |||||||||
| 0 (3) | M3 spacer | optional, suggest to panel mount | |||||||
Versions
v1.0: first release.
Assembly
Building is straightforward, just decide on whether CONN1 is the typical DB-25 or a pin header.
License
wcore_line-transmit.txt · Last modified: 2018/12/18 09:39 by latigid_on
