A slightly more compact version of the MBHP Line Driver Transmitter.
The two obvious differences are the J3 jumper (disconnects +5V from being sent) and the addition of a 100mil header. This way a DB-25 (or something else?) with ribbon cable mounting could be positioned off-board and wired to the line driver with an IDC.
Resistors | |||||||||
0 (2) | 100R 5% | THT | not really needed | ||||||
Capacitors | |||||||||
2 | 100nF | THT 2.5mm | C1, C2 | ||||||
ICs | |||||||||
2 | MC3487 | DIP16 | IC1, IC2 | ||||||
IC sockets | |||||||||
2 | DIP16 | ||||||||
Headers | |||||||||
2 | 1*2 | male | |||||||
1 (0) | 1*3 | male | |||||||
2 | 2*5 | male | |||||||
0 (1) | 2*13 | male | |||||||
Sockets | |||||||||
1 (0) | DB-25 | female | |||||||
Hardware | |||||||||
0 (3) | M3 spacer | optional, suggest to panel mount |
v1.0: first release.
Building is straightforward, just decide on whether CONN1 is the typical DB-25 or a pin header.
