====== XYZ-IR-Controller ====== Hack a Alesis PhotonX25 XYZ-Dome-IR controller\\ or how to DIY\\ {{:phatline:xyz-ausfuehrung.JPG?800|}}\\ ===== Introduction ===== The XYZ Dome works with 1 IR DIODE, and 4 IR Transistors, which are connected to 2x Stereo Audio ADC 24Bit running on Wordclock...\\ I dont know if i can get the Alesis ADCs running (AL1101) - see Datasheet {{:phatline:al1101-datasheet.pdf|}} \\ maybe i only remove the DACs and connect them to J5A! ==== PCB/Shematic ==== first a took a shot of the Front&Back of the IR-PCB... then i matched it, and redrawed every path...\\ {{:phatline:xyz-pcb-all.JPG?800|}}\\ i removed the orginal picture:\\ {{:phatline:xyz-pcb.JPG?800|}}\\ ==== MB MODs ==== How to get it working without touching a SERIAL PROTOCOL?\\ dont using the onboard DACS, instead use the MB-Core STM32F4 J5A AIN-Port....\\ {{:phatline:xyz-pcb-mod.JPG?800|}}\\ Negative: using a lot of bandwith. ====== Hardware Requirements ====== **Midibox:**\\ * [[home:mbhp:module:core32]]\\ * [[http://ucapps.de/mbhp_midi_io.html|1xMidi IO]] connect 1 midicontroller and 1 Note/Clock-Source/Destination\\ ===== To Do ===== all...!\\ ====== Community users working on it ====== * **[[Phatline]]** = Programming, Documentation...\\
