dipboard32
dipBoard32
MIDIbox Hardware Platform extension for dipCore32.
Features
  • Very small size 65x46mm(less than your credit card).
  • Very low profile.
  • Your application board can be stacked on bottom with 'Micro-match' connectors.
  • The dipCore32 can be installed on the two side.
  • Provides all the most important features and ports as a regular mbhp.
  • Compatible with Andy's USB and RES-SD modules.
Dimension
PCB
2 layers PCB design.
Fits 2 layer mostly common design rules.
  • min. drill 10mil
  • min. width 6mil
Top copper
Bottom
Ports and features.
toDo
Compatible/stack-able boards options
  • M16 Interface, stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO.
toDo
dipboard32.1535637102.txt.gz · Last modified: 2018/08/30 13:51 by antichambre
