euro-aout-ng-connector-board
EuroRack - AOUT-NG - IO-Port and Frontpanel
PCB Size is 100x40mm
Hardware Requirements
  • Soldering Iron - with a Dip that can Handle Thruhole-Parts solder Paste…
  • The other Parts from the BOM
  • a Midibox Core32 + Aout-NG
Building and BOM
All necessery Information is printet on the PCB, but also check the Shematic…
Mouser:
RefQmouserTypeFootprintDescription
J51517-30316-60022×8 Pin Header2×8 Pin Header 2.54 * 2.54 Pitchto connect to Aout-NG J5
J52710-612016230212×8 Pin Header2×8 Pin Header 2.54 * 2.54 Pitchto connect to Aout-NG J5
U31771-74HC14D-T74HC14SOIC-14SOLDER SKILLs
Cable1617-09180407001Flata quantity forEver - you may have that already
4x Leiterplatten Montageblock aka Standoffs 100x summed 30€
You will also need M3 Screws - 4 off them…
Also here it is clever to order 100 pieces for a cheaper price - you will need this on all my projects…
if you order the PCB via my Gerbers you get 4 PCB on 1 100x100mm PCB… on JLCPCB you get min 5 of thes PCBs… so you may order the needet Parts 20x times
Frontpanel
Recommend Material
2mm x 128.5 x 17.78 Aluminium, anodised
A cheaper way is: order a 1,6mm thick Aluminium PCB as Frontpanel:
I will test this… later the gerbers:
To Do
waiting for the PCBs and Panels…
Community users working on it
  • Phatline = PCB & Shematic, Documentation…
euro-aout-ng-connector-board.txt · Last modified: 2022/01/26 03:27 by phatline
