Welcome to the MIDIBox Knowledge Base
What is MIDIBox?
MIDIBox is a do it yourself custom midi controller solution. You can use the resources on these pages to build your own custom MIDIBox based midi controller. A more thorough introduction can be found here.
This knowledge base is a wiki
The MIDIBox community works hard to maintain and improve this knowledge base. You can help! Feel free to add or correct things. You need a MIDIBox forum account to edit these wiki pages. If you want to discuss documentation or wiki issues, please post in the forum. If you're posting a question in the forum, be sure you look for the answer first by searching this wiki, uCApps.de, and the forum itself.
About
MBHP Acronyms - Acronyms and abbreviations often used here. If you don't know what
AIN or
BS means… just look it up before you continue!
References - Links, Book Reviews and Specification References: Look it up!
uCApps.de uCapps.de The homepage of Thorsten Klose, the creator of MBHP & MIOS with loads of documentation
MIDIbox Devices
MIDIbox Projects - MIDIbox devices like Controllers, Synthesizers, Sequencers and all sorts of different DIY-projects. You will find tutorials, manuals, descriptions and links for over 20 both official as well as inofficial user projects - for example the famous
MIDIbox SID Synthie or the
MIDIbox Sequencer.
MIDIbox Hardware Platform (MBHP)
MBHP - the MIDIbox Hardware Platform with detailed informations about available modules (eg. the
Core Module)
Parts - Where to order, part references (eg. how to connect an Encoder)
Basics - How to get started, things you'll need, Soldering, Tips & Tricks
MIDIbox Community
Users – Create your own page and show what you're doing with your midibox!
User Projects - Add your projects, codes, pictures here! You can find a lot of cool customized boxes!
MIDIbox Operating System (MIOS)
MIOS - The MIDIbox Operating System
Tools - Available software and special helpers required to communicate with your Box, eg.
MIOS Studio
Help make the wiki better campaign
