Konga Trigga
Konga > Mic > Preamp > Schmitt Trigger > uController + KeyboardNotes Input = Drum Triggerd Notes
Introduction
Features
- convert Microphone - Pulses to Midi-Drum/Melody-Retrigger
Hardware Requirements
PCB:
Audio PCB
DipCoreF4 PCB
UI PCB
Midibox:
Schmitt-Trigger:
TS-274 OP-Amp
14 Pin - DIP-Socket
Pin-Header 2x5Pins (to connect the PCB to Core J5A)(you will also need a cable 4 that)
Resistor R1 22K
Resistor R2 4K7
Resistor RFB 100K
Resistor for Output-Gain-Reduction 100K
2x Electrolyt Capacitor 0,67uF (to decouple audio in and out)
Electrolyt Capacitor 10uF for Supply
Capacitor 100nF to denoise the OP-Amps-Rails…
2 Audio Cables+Sockets for the connection to the Recorder (6,3 mono jacks)
Firmware
How I Use It - built in Rack
Resources
