LRE8x2 096 SSD1306-BAR for Eurorack V2
I made this PCBs to use it with Fairlightii´s mb-lre8x2cs_pcb
PCB
I didnt panalize it, so you have to do this when ordering the PCB online
you will need 4 PCBs per LRE8x2… normally you want to order 8 PCBs (using 2x LRE8x2)
Here are the gerberfiles for production - i made it withJLCPCB
lre-oled-bar2-gerber.zip
Hardware Requirements
- http://www.ucapps.de/mbhp_core_stm32f4.htmla MIOS32 Core to connect too
 - DisplayDriver-SMD which buffers the Displays
 - mb-lre8x2cs_pcb for its nature use
 - LRE5-LCD2 as UI to handle Patch management and automation (if you want to use my code…)
Shematic
Building and BOM
Following Quantity is for 1 PCB (you may need this up to 8 times!:
2x 1Row 7Pin Male headers (2.54mm pitch) - normally delivered with the Displays!
2x 8PIN Ribbon Connectors (2x4Pin Female) + Cables mouser
2x 8PIN Ribbon Terminals (2x4Pin Male) SMD Variant at JLCPCB
2x 0.96“ SSD1306 Screens 7Pin Variant! i recommend white ones at Ali express
Frontpanel
I made a DXF File which you can send to Formulor in Germany
i panalized it so there are 2 Plates in it
I payed 40€ summed for booth plates incl shipping from Germany to Austria
Recommend Material from Formulor:
3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)
To Do
The LRE-OLED-Bar  &  The Frontpanel are a Part of my MSQ-CC-LRE-V2
so look there for more information….
Community users working on it
