tm5-dindoutgate
TM5-DinDoutGates
this is one essential part for my triggermatrix5
it gives 24 Digital Inputs, and 32 Digital Outputs, while 16 Outputs are used for UI, the othere 16 are buffered, and are for use as 16 GAte/Triggger output at 5V Level
i created this board. its fully SMD, and made it pick and place ready - so no soldering required!
Shematic
Building and BOM
Its build by pick and place robots… so no need to build
BOM
qty reference value footprint jlc
18 C1 – C12, Ca3, Ca4, Ca5, Cb3, Cb4, Cb5, Cb6 100n C_0402 C307331
5 C9, Ca1, Ca2, Cb1, Cb2 10uF C0805 C440198
5 DIN1, DIN2, DIN3, Gate1, Gate2 Gates Pin-Head-10-SMD C124391
4 DOUT1, DOUT2, Jin8/1, Jout8/9 DIN/DOUT Pin-Head-10-SMD C124391
4 IC1, IC2, IC3, IC4 74HC595-bigger HC595-smd C5947
3 IC5, IC6, IC7 74HC165-bigger HC165-smd C5613
1 LED1 LED LED-0603 C2286
16 Q1 – Q16 MMBT3904-7-F MMBT3904-7-F C20526
16 R1 – R16 220 R_0805 C25294
42 R17 – R74 10K R_0402 C25744
16 R33 – R48 10K R_1206 C17902
2 R75, R76 220 R_0402 C25091
To Do
waiting for the assembled Prototype
Community users working on it
  • Phatline = PCB & Shematic, UI-Programming, Documentation…
tm5-dindoutgate.1672064657.txt.gz · Last modified: 2022/12/26 14:24 by phatline
