tm5-dindoutgate
−Table of Contents
TM5-DinDoutGates
this is one essential part for my triggermatrix5
it gives;
24 Digital Inputs
32 Digital Outputs
* while 16 Outputs are used for UI
* the other 16 are buffered, and are for use as 16 GAte/Triggger output at 5V Level
The Board is fully SMD, and made for pick and place - so no soldering required!
Shematic
Building and BOM
Its build by pick and place robots… so no need to build
BOM
qty | reference | value | footprint | jlc |
18 | C1 – C12, Ca3, Ca4, Ca5, Cb3, Cb4, Cb5, Cb6 | 100n | C_0402 | C307331 |
5 | C9, Ca1, Ca2, Cb1, Cb2 | 10uF | C0805 | C440198 |
5 | DIN1, DIN2, DIN3, Gate1, Gate2 | Gates | Pin-Head-10-SMD | C124391 |
4 | DOUT1, DOUT2, Jin8/1, Jout8/9 | DIN/DOUT | Pin-Head-10-SMD | C124391 |
4 | IC1, IC2, IC3, IC4 | 74HC595-bigger | HC595-smd | C5947 |
3 | IC5, IC6, IC7 | 74HC165-bigger | HC165-smd | C5613 |
1 | LED1 | LED | LED-0603 | C2286 |
16 | Q1 – Q16 | MMBT3904-7-F | MMBT3904-7-F | C20526 |
16 | R1 – R16 | 220 | R_0805 | C25294 |
42 | R17 – R74 | 10K | R_0402 | C25744 |
16 | R33 – R48 | 10K | R_1206 | C17902 |
2 | R75, R76 | 220 | R_0402 | C25091 |
To Do
waiting for the assembled Prototype
Community users working on it
tm5-dindoutgate.1672252658.txt.gz · Last modified: 2022/12/28 18:37 by phatline
