tm5-dindoutgate
TM5-DinDoutGates
this is one essential part for triggermatrix5
it gives;
24 Digital Inputs
32 Digital Outputs
* while 16 Outputs are used for UI
* the other 16 are buffered, and are for use as 16 GAte/Triggger output at 5V Level
The Board is fully SMD, and made for pick and place - so no soldering required!
Shematic
Building and BOM
Its build by pick and place robots… so no need to build, or order any component
BOM
qty reference value footprint jlc
18 C1 – C12, Ca3, Ca4, Ca5, Cb3, Cb4, Cb5, Cb6 100n C_0402 C307331
5 C9, Ca1, Ca2, Cb1, Cb2 10uF C0805 C440198
5 DIN1, DIN2, DIN3, Gate1, Gate2 Gates Pin-Head-10-SMD C124391
4 DOUT1, DOUT2, Jin8/1, Jout8/9 DIN/DOUT Pin-Head-10-SMD C124391
4 IC1, IC2, IC3, IC4 74HC595-bigger HC595-smd C5947
3 IC5, IC6, IC7 74HC165-bigger HC165-smd C5613
1 LED1 LED LED-0603 C2286
16 Q1 – Q16 MMBT3904-7-F MMBT3904-7-F C20526
16 R1 – R16 220 R_0805 C25294
42 R17 – R74 10K R_0402 C25744
16 R33 – R48 10K R_1206 C17902
2 R75, R76 220 R_0402 C25091
To Do
waiting for the assembled Prototype
Community users working on it
  • Phatline = PCB & Shematic, UI-Programming, Documentation…
tm5-dindoutgate.1672252758.txt.gz · Last modified: 2022/12/28 18:39 by phatline
