TM5 Gate/Trigger Input
this is one essential part for my triggermatrix5
*  Levelshift from 5V to the for the MCU required 3V, with a Resistor Divider
*  Overvoltage Protectect with TVS-Diodes
*  Preamp-Section
5V, 3V or Pre-Amped input - can be set vie Jumpers and Potentiometers, the PCB itself should be mounted on the Groundplate off the housing, the housing should have a service-plate to access this Settings!:
8 Channels, are managed here, so in order to have 16channels, you need 2 off this PCBs
if you dont want a Preamp, then dont stuff the Preamp-section > this will make this PCB a lot off cheaper!
Shematic
Building and BOM
BOM
Follwing list is for reference, and debugging only, no need to order them! all the parts are already soldered on the PCB!
| Comment | Designator | Footprint | LCSC |
| 10uF | C1-18,C34-54 | 0805_C | CL21A106KAYNNNE |
| 100n | C19-33 | 0402_C | C307331 |
| - | CS1,LCD1-18,inB10,outB10,in15 | PinHead-SMD-2,54mm Pitch | C192300 |
| SN74HC541 | IC1-7 | SOIC127P780X200-20N | C116811 |
| 74HC595 | IC8-10 | SOIC-16 | C5947 |
| 220 OHM | R1-54 | 0402_R | C25091 |
| 1K OHM | R55-96 | 0402_R | C11702 |
Order-List
This Quantitys are for ONE Board, you may need 2 Boards…
copy following list into this mouser.com-Link
517-30310-6002|5
Order from Reichelt:
3x 2x20Pin Male 2,54mm Headers
4x PinHeader 2x5Pin FeMale
32x Jumper
To Do
waiting for the assembled Prototype
Community users working on it
