====== TriggerMatrix V0 ====== yes there is a 8bit Prototype, built in a Techstar made it a TEKKSTAR, but also there it was soon replaced with a 32Bit Core,\\ {{:phatline:tekkstar-final.jpg?600|}}\\ [[https://vimeo.com/115565118]] Tekkstar in use\\ it was a 8x8 LED-Matrix, with 2x8 Buttons, on Breathboard\\ {{:phatline:crumar.jpg?600|}}\\ a other 32bit Variante built in on the Upper-Manual in Crumar 198, UI-controlled via a BCR2000\\ ====== TriggerMatrix V1 ====== 32 Bit PROTOTYPE\\ {{:phatline:tm_breathboard-small.jpg?600 |}}\\ ====== TriggerMatrix V2 ====== not supported any more, it has timing issues, use the way more lightweight V3! {{ :phatline:triggermatrix-in-use.jpg?350|}} ===== What is Triggermatrix ?===== a quick but not full view into triggermatrix and sequencing (german-austrian) \\ [[https://www.youtube.com/watch?v=7Z6Hw158HU8|Triggermatrix Teaching]]\\ [[https://www.youtube.com/watch?v=T1daiaBg6EI|Triggermatrix-basics]]\\ [[https://www.youtube.com/watch?v=NkQfHLjvugA|Echtzeit Musik]]\\ ==== Teaser ==== You have spend time to program a cool rythm, and you already know which chords/melodys you want to play, and now its time to programm the timing/steps/the rythm in the melody... after quite a while of trying and looking on your drumline you have a fitting melody line for your drums... now you change the drums a bit... o no i also have to change the melody now... i make a break, a intro...oh no so much work and time...and all because, the melody is fixed in arrangement, you want a melody line that goes with beat? you want to change the beat note stream also (noteprocessing)? > read more... i have a tool for you!!! it will change your way doing LIVE!\\ get ready for JAM! \\ ==== Features ==== **Short spoken:**\\ * 16xdrumtriggers > Trigger-Routing-Matrix > Drum-Syntesizers\\ * Melody-lines > Trigger-Routing-Matrix > Melody-Syntesizers\\ \\ **Rules:**\\ * Drum-Trigger are Velocity Master > we dont care about the velocity of the Melodys\\ * There are Songs (ProgramChange), each Song has 16 different Trigger-Routings Presets> these are the Song-Parts\\ * 512 Songs saved on SD-Card, and Load-able while playing \\ * 512 System-Settings(Setups) saved on SD-Card...i use only one of it\\ * Triggermatrix midi-outs are connected to all synths, so it manage the program-change also\\ * 16x Trigger-OUTs with fixed Notes, on one midichannel - to connect Drum-Synths, Drum-Samplers\\ * 6x Polyphonic Melody-Retrigger-OUTs on 6 MidiChannels - to connect MelodySynths to it\\ * 12x Monophonic Melody-Retrigger-OUTs on 12 MidiChannels - to connect Monophonic Synths like pitchable Drums or Bass-Synths\\ * All 16 Trigger & ReTrigger-OUTs share the same Routing and Channelstrip UI (Mute, Solo, Roll...)\\ * Trigger, Poly, Mono-OUTs can be controlled seperatly by > **Random-Kill** & **Velocity-OFFSet**\\ * 6x Melody-Input-Matrix - Route & Mix Melody Inputs to the 16 Melody-Retrigger-Outs (saved in Song)\\ * 16x Melody-Input-Matrix-Hold-Buttons - hold the last Note, save it in the Patch - usefull when pitch drums.\\ \\ V1: the Matrix has also a Trigger-Sequencer built in, the Melodys have to come from anywhere else, but @ the end, they have to be plugged into the matrix...\\ **Trigger-sequencer, a few facts:**\\ * is a Drum-Step-Sequencer\\ * 256 Steps in total\\ * minimal LoopSection is 16steps = 1 Page, there are 16 pages to chain\\ * intro LoopSection, from step 0 until to the "minimal LoopSection"- is played once, then it loops the normal LoopSection\\ * The sequencer is made to give a static NoteStream, the Song-Structure is done by the TriggerMatrix\\ * Full Velocity control, visible with 3 different colours, each colour-Vel is set with its own CC\\ * Free programmable Swing to each Step, with 2 different swing Length-sets, which are controlled live via CC\\ * copy, paste, erase of pages\\ * copy, paste, erase of rows\\ * forward, backward, fw><bw - play direction\\ * Not only 4/4 are possible, all other things like 5/4 are possible! +++\\ ===== Generic Interface ===== Generic in sense of: PCBs that already out there:\\ * [[http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_seq|Wilba SEQ CS]]\\ * [[http://www.midibox.org/dokuwiki/doku.php?id=mididocs:seq:blm16x16_x&s[]=16x16|BLM16x16x]]\\ * [[http://www.midibox.org/dokuwiki/doku.php?id=MB-LRE8x2CS_PCB|LRE8x2CS_PCB]]\\ * [[http://wiki.midibox.org/doku.php?id=stm32f4_module&s[]=core32|CORE32 STM32F4]]\\ * [[http://ucapps.de/mbhp_lcd.html|2x 2x40Char Display]]\\ * [[http://ucapps.de/mbhp_midi_io.html|2x Midi IO]] * SD-Card and some wires (which all are crimpable)\\ so when you have those things, upload {{:phatline:tm_seqongeneric.zip|the Code}} & watch the videos above\\ \\ Serial Chain is: Wilba SEQ-CS and then LRE8x2\\ code is working, SEQUENCER timing is a mess, i was still a newbee in c > "learning by doing"\\ \\ here is a {{:phatline:tmongeneric-pin-out.ods|"FrontPanel+Pin-Out"}} where the functions on the WILBA CS & LRE8x2 are explained\\ {{:phatline:tmongeneric-frontpanel-functions.png?600 |}}\\ {{:phatline:tm-generic-cs.jpg?600 |}} ====== TriggerMatrix V3 ====== {{ :phatline:tm_blm_run_copy.jpg?400|}} ==== Teaser ==== V2 was Song-Structured, **V3 is to JAM**\\ in V2 where lot of UI-Elements, Menues, and Settings.\\ **V3 is stripped down and optimized:** 8 Faders, 5 Tactial Buttons, 3 Switches, 1 Encoder, + BLM16+16X.\\ its more the orginal V0 Tekkstar, there we had only a matrix a view buttons and Pots\\ 3/4 4/4 5/ 7/4... and others, is Set on the 16x16 Matrix with "on matrix text".\\ Timing now is rock-steady. And we are Sequencing on 32th\\ New is the **Clip-Launcher**, here we can Ableton-Style switch Clip-Variations and Songs\\ Now we have a **Roll-Variation Fader**!\\ ==== Features ==== **Short spoken:**\\ * 16xdrumtriggers > Trigger-Routing-Matrix > Drum-Syntesizers\\ * Melody-lines > Trigger-Routing-Matrix > Melody-Syntesizers\\ \\ **Rules:**\\ * Drum-Trigger are Velocity Master > we dont care about the velocity of the Melodys\\ * There are Songs (ProgramChange), each Song has 8 different Trigger-Routings Presets> these are the Song-Parts\\ * 256 Songs saved on SD-Card, and Load-able while playing \\ * System-Settings, like Ports or MidiChannels are Hardcodet\\ * Triggermatrix midi-outs are connected to all synths, so it manage the program-change also\\ * 16x Trigger-OUTs with fixed Notes, on one midichannel - to connect Drum-Synths, Drum-Samplers\\ * 5x Polyphonic Melody-Retrigger-OUTs on 5 MidiChannels - to connect MelodySynths to it\\ * 11x Monophonic Melody-Retrigger-OUTs on 11 MidiChannels - to connect Monophonic Synths like pitchable Drums or Bass-Synths\\ * All 16 Trigger & ReTrigger-OUTs share the same Routing and Channelstrip UI (Mute, Solo, Roll...)\\ * Trigger, Poly, Mono-OUTs can be controlled seperatly by > **Random-Kill** & **Velocity-OFFSet**\\ * 6x16 Melody-Input-Matrix - Route & Mix Melody Inputs to the 16 Melody-Retrigger-Outs (saved in Song)\\ * 16x Melody-Input-Matrix-Hold-Buttons - hold the last Note, save it in the Patch - usefull when pitch drums.\\ \\ the Matrix has also a Trigger-Sequencer built in, the Melodys have to come from anywhere else, but @ the end, they have to be plugged into the matrix...\\ **Trigger-sequencer, a few facts:**\\ * is a Drum-Step-Sequencer\\ * 256 Steps in total\\ * 32 th fixed rate\\ * 3,4,5,7,11,13/4 tact\\ * minimal LoopSection is 16steps = 1 Page, there are 16 pages to chain\\ * intro LoopSection, from step 0 until to the "minimal LoopSection"- is played once, then it loops the normal LoopSection\\ * The sequencer is made to give a static NoteStream, the Song-Structure is done LIVE by the TriggerMatrix-ROUTER\\ * Full Velocity control, visible with 3 different colours, Velocity Set via FADER\\ * Free programmable Swing to each Step, with 2 different swing Length-sets, which are controlled live via CC EDIT no CC for that right now\\ * copy, paste, erase of pages\\ * copy, paste, erase of rows\\ * fixed forward play direction\\ ===== U Interface ===== PCBs that already out there:\\ * [[http://www.midibox.org/dokuwiki/doku.php?id=mididocs:seq:blm16x16_x&s[]=16x16|BLM16x16x]]\\ * [[http://wiki.midibox.org/doku.php?id=stm32f4_module&s[]=core32|CORE32 STM32F4]]\\ * [[http://ucapps.de/mbhp_midi_io.html|2x Midi IO]] * SD-Card and some wires (which all are crimpable)\\ so when you have those things, upload {{:phatline:tm_V3.zip|the Code}} & watch the videos above\\ \\ Extendet UI via GPIO via J10AB, J5AB:\\ \\ {{:phatline:tm_blm_run_back.jpg?800 |}}\\ {{:phatline:tm_blm_gpio_extra07..jpg?400 |}}{{:phatline:tm_blm_gpio_extra08..jpg?400 |}}\\ {{:phatline:tm_blm_gpio_extra00..jpg?400 |}}{{:phatline:tm_blm_gpio_extr01..jpg?400 |}}\\ {{:phatline:tm_blm_gpio_extra1..jpg?400 |}}{{:phatline:tm_blm_gpio_extra05..jpg?400 |}}\\ ===== Community users working on it ===== * **[[Phatline]]** = Programming, Documentation, Hardware-Prototype, Testing, Jamin...\\ ===== Getting Involved ? ===== Just let a Private message on the forum to user already involved
