====== 16th fixed PolySequencer ====== {{:phatline:16th_fixed_poly-test-setup.jpg?400 |}}\\ {{:phatline:16th_fixed_poly-footboard.jpg?800 |}}\\ ===== Specs ?===== **4 Midi-Channels: 1 2 3 4**\\ --2 Tracks a Channel\\ --8 Notes-Chord a Track\\ --each track has a dedicated and changeable loop-length from 16 to 256 Steps (example for 4-4)\\ --each Track can played single and booth tracks can be played simultan/in-dual\\ **Fixed Velocity @ 127**\\ --no Keyboard-Velocity-sense ([[Triggermatrix]] does the job of sensing drum trigger in order to re-trigger the moldy buffer\\ **16th fixed note-trigger-rate**\\ --puts out note-data in 16rate (in order to provide a steady note stream for [[Triggermatrix]])\\ --a connected [[Triggermatrix]] (allows not only 4-4, all other things like 5-4 are possible!)\\ --[[Triggermatrix]] does the job of melody-rythm-re-triggering}\\ **512 Songs saved on SD-Card**\\ --Load-able while playing - when the beat-structure is the same\\ ===== the Midi-System-Setup ===== --fixed/hardcoded (Midi-Ports, Midi-Channels))\\ **MidiPort 32-in:**\\ --Midi-Clock-Source, Start-Stop, ProgramChange @ MidiChannel 1\\ **MidiPort 33-in:**\\ --connected to a Midikeyboard @ MidiChannel 1\\ **MidiPort 33-out:**\\ --connected to [[Triggermatrix]] -Melody-In-Port, or a poly-synth)\\ ===== Footboard-Interface ===== * Footboard/old Pulp-Radio-like wiring!\\ * 2x8 Foot-Tactial-Buttons + 2xBank-Tactial-Buttons\\ * 2x8 LEDs to Display Foot-Buttons-Status\\ * 2x4 Bank indication Leds\\ * 2x Foot-Tactial-Button-Banks\\ * [[http://wiki.midibox.org/doku.php?id=stm32f4_module&s[]=core32|CORE32 STM32F4]]\\ * [[http://ucapps.de/mbhp_lcd.html|3x LCD with 2x40-Signs, to display Chord-Notes, for sequenced notes and keyboard-inut-notes]]\\ * [[http://ucapps.de/mbhp_midi_io.html|2x Midi IO]]\\ * 8x 15Led-LedRings\\ * 2x DoutX4 Modules\\ * 1x DinX4 Modules\\ * cables, isolaton material, solder \\ * wood, Screws, Drills, Drilling-Machine, a saw for the Display-Cut-Outsl, a Fill\\ * M3 Distance-Stamps to mount the pcps\\ * SD-Card\\ {{:phatline:16th_fixed_poly-footboard-inside1.jpg?600 |}}\\ {{:phatline:16th_fixed_poly-footboard-inside2.jpg?600 |}}\\ {{:phatline:16th_fixed_poly-footboard-inside3.jpg?600 |}}\\ ===== fabricated PCB-Version ===== not planed! ===== Community users working on it ===== * **[[Phatline]]** = Programming, Documentation, Hardware-Prototype ===== Getting Involved ? ===== Just let a Private message on the forum to user already involved
