BLM16x16+X V2 - Board
Since i need need a BLM16x16+X for my triggermatrix5 And since Latigid ONs BLM is sold out blm16x16_build_guide… (and those 1N4148 Thruholes nightmare..)
I made this new Version, based on Latigids Shematical Improvements.
Shematic
Building and BOM
The Values are printet on the PCB.
blm16x16-pcb-back.pdf
blm16x16-pcb-front.pdf
Following Quantity is for 1 PCB, Mouser:
open following link: https://www.mouser.com/tools/part-list-import.aspx
& copy past follwong list:
187-CL21B104KBFWPJE|7
187-CL21A106KPFNNNE|4
81-GRM219R60J476ME4D|4
652-PEC11R-4015F-S24|9
710-61201021621|3
667-ERJ-P06F1001V|6
660-RK73H2ATTD1002F|27
660-RK73H2ATTD1002F|3
 the 3x hc165 are missing
You may change the how many times you want to order this project
aka you need it 10 times, then do this after importing the list into mouser…
if you need it 10 times it cost around 199€
6 Displays which you get from Ali:
SSD1306-128x64 7pin White
To Do
make a Frontpanel.
Community users working on it
or join the forum: daw-controller-ableton
