clock2audio2clock
clk2a2clk
Midiclock 2 Audio Converter, Audio 2 Midiclock Converter
4 Recording a Midiclock on a Audio-Track on your Multitrack-Recording-Device
in order to get the possibility to overdub a sequencer track on Recording Devices without Midi-Clock builtin
Introduction
i fell in love with a zoom livetrack-l12, a multitrack-audio-recorder, in a compact design, severell submixes, parametric eqs, compressor, efx and a extra master-track-recording, and that for a good price…
but it doesnt have midi… in specially it does not have a midiclock.
so when i have to make a track new, or i want to overdub a track, a track that is Midiclock-Driven a sequencer track for example…
So with this device, i lose one Audio-Track, because i use this one Audio-Track, as a Click-Track, it records Audio-Rectangle-Pulses, which are a converted Midiclock-Pulses
when i then playback the Click-Track-Recording, it converts this Audio Pulses back to Midiclock-Messages.
Thats all, not much code, stripped down, running thight.
Features
- convert Midi-Clock-Data to Audio-Pulses
convert Audio-Pulses to Midi-Clock-Data
Hardware Requirements
  • Clock Source aka Sequencer: midibox_seq_v4l
  • a Synth: JP8080
  • a Multitrack-Audio-Recorder: Zoom Livetrack L12
  • 3x Midi-Cables
Midibox:
Schmitt-Trigger:
  • TS-274 OP-Amp
  • 14 Pin - DIP-Socket
  • Pin-Header 2x5Pins (to connect the PCB to Core J5A)(you will also need a cable 4 that)
  • Resistor R1 20K
  • Resistor R2 4K7
  • Resistor RFB 100K
  • Resistor for Output-Gain-Reduction 100K
  • 2x Electrolyt Capacitor 0,67uF (to decouple audio in and out)
  • Electrolyt Capacitor 10uF for Supply
  • Capacitor 100nF to denoise the OP-Amps-Rails…
  • 2 Audio Cables+Sockets for the connection to the Recorder (6,3 mono jacks)
Frontpanels
MBHP
Software
Firmware
V1.2017clk2a2clk.zip hardcodet no menue, no nothing, stripped down to max performance
To Do
Upload Video on Youtube - with the use with a Zoom Livetrack L-12 Multichannel Recorder
How I Use It - built in Rack
Resources
Community users working on it
  • Phatline = Programming, Documentation…
clock2audio2clock.txt · Last modified: 2018/05/04 21:04 by phatline
