drumstuff
FIXME Update thing out there
A place to catalogue analogue drum experiments, clonings, mods, hacks, bends, MIDIbox integration, specialised drum sequencers, MBSEQ firmware, SID as drum machine, triggering, E-Drum heads etc etc etc.
MIDIBox SEQ v2 - a simple control surface can be built with 16 LEDs/switches and one encoder (according to the SEQ Drum Mode tutorial below), and still have full access to this amazing sequencer engine. Up to 48 seperate MIDI drum note assignments x 16 steps.
Can also take an AOUT module for up to four CVs outs. The DOUTx4 expansion mentioned under MIDIO128 below could possibly be coded in.
With added code, a LED matrix to display all drum patterns simultanously may also be possible, as in the Simmons SDS6. Moxi has already implemented a 4×16 button/LED matrix, and TK has indicated up 1024 may be possible (in MIOS, not necessarily in the SEQ). 4x16 LED matrix wiring - PDF. Also see the Sparkfun parts listed below.
MIDIO128 - up to 128 on/off signals and 128 input switches from one core. Useful for a simple fixed velocity MIDI to trigger/gate converter, sequenced from other equipment or software. A user adaption has added a DOUTx4 module for another 32 fixed velocity trigger outs.
MIDIBox CV - 8 gates and 2 analog CVs per AOUT module. Could be adapted for velocity triggers?
TR Sequencer - Discussion on the classic Roland TR-x0x drum sequencer user interface
DSEQ32 - mess's 32 step 8 track drum sequencer
MIOS Downloads - Code examples for:
* 8 CV outputs with the MBHP_AOUT module
* button matrix of 8×8 = 64
* 64 CV INs and OUTs
* 64 pots, 128 buttons, 128 LEDs
* velocity buttons (e.g. for drumpads)
* MIDIBox SID - steal matrix code
* MIDIBox SEQ
Forum topics:
Other resources
V-Trig, S-Trig and Gate - from Wikipedia
Gates and Triggers, Mystery Solved - from synthesizers.com
PIC MIDI programming - getting started
VC LFO and ADSR on PIC 16s - cloning analogue LFO and ADSR with PICs.
Drum pads and EDrums
A good piezo pad design
EDrum For Free - great DIY site, heaps of designs for pads, triggers, pedals, hats etc
Yahoo Groups
TR-707 - Service manual, schematics, mods: you'll need to join to access files.
Drummachine - moderator approval to join
Roland Drum Machines
rolandtr505
Simmons_Drums - schematics and service manuals galore
Circuit Bending - just a list of search results
Useful Parts
RGB Matrix
Sparkfun Electronics have an 8x8 RGB LED Matrix with an SPI serial controller attached for $59.95. Red/Green version $34.95, matrix only small $4.95 large $29.95.
The serial controller backpack contains a reprogrammable AVR ATMega8 microcontroller, which bumps up the value equation and opens a world of possibilities, such as LED sensors.
4×4 lighted key matrix
According to this forum thread, Sparkfun will also soon be offering “silicone illuminated buttons … 4×4 arrays that will cost between $20 and $30 U.S … with 5mm holes for our tri-color LEDs.”
High power shift register
Shift register 8 bit high power - serial in, 8 pins out at up to 50V/150mA each. $1.95. Sparkfun again :) This would be handy for triggering modules that expect more than +5V as from a DOUT.
Schematics:
S-Trig to V-Trig converter - also see below. 505/707 internal triggers are S-Trig.
V-Trig to S-Trig converter - different one below
Simple switch/trigger with transistors - ground switch with NPN or +ve pulse with PNP. The example given uses a PC parallel port and the BendControl Win95 sequencer
Arista Drum machine
SynthOllie's scans - Boss PC-2 Percussion with noise generator mod, Boss handclap, Casio VL-1, clap, synbal, synclap, syntom II.
Matrixsynth blog entry - where I got the link to synthollie and also a SynTom II and Cymbal II Zip file.
Papareil Synth Labs - Coron Drum Synth clone schematics, also lots of other FX and synth modules, MIDI projects, etc.
Roland TR-505 8x trigger out mod
R80 - Kick
R75 - Snare
R2  - Clap/Rim
R69 - Cowbell
R68 - Conga
R63 - Hats
R62 - Ride/Crash
R60 - Toms
This will produce a voltage
trigger in response to an
s-trigger out.  The trigger                 Off
voltage will be 0 or 9 volts.            ___o       ___________
Close the switch to use, open           /          | 9-volt    |
it to save the battery life.     |-----o    o---- +| battery   |-- ground
                 ________________|          On     |___________|
             10k \           10k \
                 |               |----------------------- to tip of jack
                 |               |                        sleeve to ground
                 |    100k       /
      ___________|___/\/\/\___|/
      |                       |\   2N3904 or equivalent
1   -|-  S-trigger              \
    _____     in                 |
2    |                          |
      |                  ground  -
     ---  ground
V-Trig to S-Trig (another)
The circuit that I have is very simple. One VMOS FET (something like the
VN10KM). No power, nothing...
it's something like:
                       S|-----------------o S-Trig
                    G |   |
       trig o---------|   |
                      |___|
 V-Trig.                | D
        gnd o------------------------------o gnd
where G, S, and D stand for Gate, Source and Drain - and I may have them
mixed up, coz I'm doing this from a bad memory)
To do:
* MBFM drums (duh)
* Jamaroonies
* 505/707 as trigger source
* LED matrix
drumstuff.txt · Last modified: 2016/06/13 13:00 by psykhaze
