fadercore_-_vlr-8enc
Fadercore
Standard 220mm wide modules
VLR-8Enc
A PCB to add 8 Encoders with LED ring for each.
Eagle Files: https://github.com/novski/Midibox/tree/master/VLR-8Enc
BOM
BIll of Material
Allways look for the cheapest seller, the Price may vary heavy!!! And look for Local dealers preferred. http://www.midibox.org/dokuwiki/doku.php?id=where_to_order_components
The Encoders
I was fascinated about the RGB Shaft of this Encoder so i developed all opon this nice piece. Its not the cheapest but i sell them for a reasonable price.
And its still possible to use a non Illuminated Encoder.
The other Materials: Mouser
  • 2x10pin Header, 517-30310-6002
  • 2xULN2803, 595-ULN2803ADWR
  • 9x100nF,594-K104K15X7RF53K2
  • 6x10k, 774-77061103P
  • 4×220, 652-4816P-T1LF-220
  • 3×220, 660-MF1/2LCT52R221J
  • 3x74HC165D, 771-HC165D652
  • 3x74HC595D, 771-74HC595D
  • 3xTPIC6B595, because the MOQ is 250 i deliver them for you with the PCB.
  • 88xLED RED, 604-WP3A8HD
  • 88xLED holder 6mm Height, 749-ELM-5-6MM
Project Order Basket on Mouser: http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=a6dbae9ab7
The PCB is available under: http://vlrlab.com/lang/17-8enc.html
  • 8 Encoder, 652-PEL12T4226FS1024 not on Projectlist because i deliver cheaper and with cap.
How to get Started
Prepare the PCB
Prepare the Connection
Test it in MIOS
fadercore_-_vlr-8enc.1406447299.txt.gz · Last modified: 2014/07/27 07:48 by novski
