−Table of Contents
Konga Trigga
Konga > Mic > Preamp > Schmitt Trigger > uController + KeyboardNotes Input = Drum Triggerd Notes
Introduction
Features
- convert Microphone - Pulses to Midi-Drum/Melody-Retrigger
====== Hardware Requirements ======
PCB:
* Audio PCB
* DipCoreF4 PCB
* UI PCB
Midibox:
* dipcoref4
* Soldering Iron, Wires, PCB….
* USB Power Supply
Schmitt-Trigger:
* TS-274 OP-Amp
* 14 Pin - DIP-Socket
* Pin-Header 2x5Pins (to connect the PCB to Core J5A)(you will also need a cable 4 that)
* Resistor R1 22K
* Resistor R2 4K7
* Resistor RFB 100K
* Resistor for Output-Gain-Reduction 100K
* 2x Electrolyt Capacitor 0,67uF (to decouple audio in and out)
* Electrolyt Capacitor 10uF for Supply
* Capacitor 100nF to denoise the OP-Amps-Rails…
* 2 Audio Cables+Sockets for the connection to the Recorder (6,3 mono jacks)
====== Firmware =====
V0.2018clk2a2clk.zip write code
====== How I Use It - built in Rack ======
===== Resources =====
Schmitt-Trigger-Calculator
====== Community users working on it ======
* Phatline** = Programming, Documentation…
